Old 05-14-2008, 11:55 AM   #1
ImRickJamzBIttch
ImRickJamzBIttch's Avatar
ImRickJamzBIttch is making his/her stupidity well-knownImRickJamzBIttch is making his/her stupidity well-knownImRickJamzBIttch is making his/her stupidity well-knownImRickJamzBIttch is making his/her stupidity well-knownImRickJamzBIttch is making his/her stupidity well-known
s13 1989 hatch stereo wiring
hey there i just got another hatch..but it came with no stereo..and they old owner threw in a JVC KD-g420..and i was woundering if any one can help me out...do i just color match? or is there certain wire i connect with other?..am not much a wiring oerson..so anythin suggestions will help..thanks
ImRickJamzBIttch is offline   Reply With Quote
Old 05-14-2008, 11:58 AM   #2
blackrms13
blackrms13's Avatar
i'd say from my exp, just color match
my hatch used to have a old HU, i cut off the wires, and color match'd to new HU, worked perfectly
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 05-14-2008, 12:10 PM   #3
Adam240
Adam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of lightAdam240 is a glorious beacon of light
I hate this more then anything.. Its stupid to cut the harness. It cost like $15 for a pigtail to wire your stereo up with.
Adam240 is offline   Reply With Quote
Old 05-14-2008, 12:26 PM   #4
blackrms13
blackrms13's Avatar
i dont see whats wrong with that, i can disconnect the plug thing anytime i want....plus i didnt cut the "car" end...but the HU end...
Old 05-14-2008, 12:33 PM   #5
g6civcx
g6civcx's Avatar
Take it to Best Buy. Pay them $50 to install. Let them deal with wiring.
If you're anal, after you go home, take out the deck and solder the wires together instead of using connectors.
Otherwise, bust out the FSM-EL section and read the stereo wiring section. Follow the wire colours and match to your deck. You can use a harness, or clip off the OEM harness and solder.
I recommend using a detachable harness. Crutchfield sells one for about $10-15. It makes it easier to change decks later. Plus it's easier to solder out of the car than in the car.
There is a soldering thread in Tech. If you have any specific questions about colours, post up.
