Old 05-16-2008, 07:01 AM   #1
On2
On2 is a well-known jackass
What dual pass radiators are available?
I've been doing some searching for a dual pass radiator for the KA24DE and have only found the C&R Racing and the one that Hinson Supercars offers. Unfortuntely C&R Racing does not make that radiator anymore and for them to make one is over $700. The Hinson Supercars radiator is$600 but includes dual electric fans and the necessary hardware.
Anyone know of any other dual pass radiators?
Thanks
On2 is offline   Reply With Quote
Old 05-16-2008, 07:10 AM   #2
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Is dual pass the same as dual core? If so then Mishimoto is a great bang for the buck. Next would probably be KOYO.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 05-16-2008, 07:39 AM   #3
v-empire
Trader Rating: (22)
v-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nicev-empire is just really nice
Feedback Score: 22 reviews
Send a message via AIM to v-empire
griffin does i believe..
i may have one for sale.
they gave me one, nib.
i believe they said it was a three row.
www.sexypants.org
v-empire is offline   Reply With Quote
Old 05-16-2008, 08:47 AM   #4
Sileighty_85
Sileighty_85's Avatar
just get a Koyo Aluminum with a Nismo Thermo, and you should never go over 70*C ever again (unless you run A/C)
Phase 2 has'em on sale for $285 right now
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-17-2008, 05:50 AM   #5
On2
Thanks for the suggestions but my build requires a dual pass stock location (KA24DE) radiator.
Rows and passes are not the same.
Seems like I'll have to order a C&R Racing one-off piece.
Old 05-17-2008, 10:02 PM   #6
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
correct. Dual Pass is way different than dual core.
dual pass the coolant actually passes through one side of the radiator endtanks through the radiator to the other tank, and then back through again and out through the other radiator outlet.
C&R is the way to go.
Coolwhip is offline   Reply With Quote
Old 05-17-2008, 11:42 PM   #7
FRpilot
FRpilot's Avatar
yep, as far as i know, dual pass the fluid flows through the radiator twice.
koyo makes one, but i think its for sr only for now.
FRpilot is offline   Reply With Quote
Old 05-17-2008, 11:47 PM   #8
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
First few posters- get yursulfs edumacated. j/k.
As already stated, dual pass is very different. I don't know what type of a build you are doing or how pretty it needs to be, but look into circle track racing radiators. They are DUAL PASS and CHEAP. By cheap i mean 1/3 of the prices you are mentioning.
gotta240 is offline   Reply With Quote
Old 05-17-2008, 11:56 PM   #9
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
I have a nismo low temp thermostat, N1 water pump, and a griffin rad.
and my fans kick on quick at 180 deg. i usually stay around 200deg with that setup. and i remover anyhting in bay that was related to the AC.
this is on a RB25 that is, but point is that you can always improve cooling as long as you are past the op temp of the engine.
Tenchuu is offline   Reply With Quote
Old 05-18-2008, 06:37 AM   #10
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Like others have mentioned, try looking for circle track stuff. Summit sells nice DP rads for under $300, and you might find something good on ebay from the Nascar surplus type of sellers. I got lucky and got a C&R DP for an SR with a huge SPAL fan used last year, but they're definitely not common or cheap.
turtl631 is offline   Reply With Quote
Old 05-18-2008, 02:37 PM   #11
anotherblusi
anotherblusi is an unknown quantity at this point
Griffin dual passes are about 600-700. You have to call and custom order it. You just tell them you want a ka radiator but in a dual pass design. You can also specify how thick you want the core. The only problem is that it takes about a month to receive it once you order it.
Also you can't really have a dual pass or really need it for an SR, because of the opposite radiator inlet and outlets. This helps to spread water across the entire radiator, as opposed to the ka inlet and outlet design, which allows water to flow directly down and not properly spread.
Also even for single pass radiators, griffin kills koyo. I have used koyo on multiple cars, and everytime they overheat when being driven hard in hot weather. Griffin radiators have yet to fail me...
anotherblusi is offline   Reply With Quote
