Old 02-21-2003, 02:49 PM   #1
gregsr20
gregsr20's Avatar
gregsr20 is an unknown quantity at this point
my sr20det won't crank?!
I sent my wiring harness to unstable hybrids to get wired, installed the motor, and it didn't crank. I tried troubleshooting like jumping from battery to starter and it turned but wouldn't fire, i hooked a test light to the coil pack, and there was no fire, any suggestions?
fast cars are dangerous, save lives drive HONDA'S
gregsr20 is offline   Reply With Quote
Old 02-21-2003, 03:06 PM   #2
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Go through that wiring harness bit by bit. Make sure that no solders accidentally broke loose. Double check the tranny harness as well.
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 02-21-2003, 03:07 PM   #3
gregsr20
gregsr20's Avatar
i tried following the wires of the tranny, but they were hot and no luck there, do you think it is an ecu relay
Old 02-21-2003, 03:09 PM   #4
DuffMan
DuffMan's Avatar
First thing, when you turn the key to on, can you hear the fuel pump start up? If you do, this would verfiy that ecu has power and is working and you could go from there.
Old 02-21-2003, 03:13 PM   #5
gregsr20
gregsr20's Avatar
yes fuel pump is on, all lights work, radio, dome etc. car functions electronically, just no crank, ecu light is also lit up, and stays lit
Old 02-21-2003, 03:15 PM   #6
silnv
silnv's Avatar
Trader Rating: (39)
silnv is an unknown quantity at this point
Feedback Score: 39 reviews
Send a message via AIM to silnv
You say it rolls over but wont fire, right? It is possible you may have your fuel lines on backwards I did this with mine. Maybe check your plugs and make sure they spark.
1997 Nissan 240sx
1991 Nissan 240sx hatch
silnv is offline   Reply With Quote
Old 02-21-2003, 03:58 PM   #7
gregsr20
gregsr20's Avatar
I am getting fuel, i have compression, but no fire
Old 02-21-2003, 04:01 PM   #8
gregsr20
gregsr20's Avatar
I'm getting desperate people, i have offered to give away an old beaten up el camino to a preacher mechanic to see what he could do, my hopes are high, but expectations are low, please help, any one want an el camino, lol
Old 02-24-2003, 07:50 AM   #9
gregsr20
gregsr20's Avatar
i checked my ignitor chip for power and it is ok too, i need help guys, it makes me sick to see her in the garage w/o life
Old 02-24-2003, 08:02 AM   #10
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
Another thing I would do is pull your coil packs. Unbolt them and one at a time, try to turn the car over holding one of them outside the head but close enough to check for spark. This could be an issue for you.
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 02-24-2003, 08:25 PM   #11
Racer X
Racer X is an unknown quantity at this point
Send a message via AIM to Racer X Send a message via Yahoo to Racer X
there is a relay in the front right corner of the car are sure that it is pluged in? cause this relay that is behind the battery controls the starter solinoid (i forgot to plug it in once, lots of head scratching)
Twin67 ls1/awd in the works
Racer X is offline   Reply With Quote
Old 02-25-2003, 10:12 AM   #12
gregsr20
gregsr20's Avatar
i am off of work tommorow, i've got some ideas of things to look for, if i get her runnin', i let you guys know, appreciate the help
Old 02-25-2003, 11:36 AM   #13
Racer X
the main coilpack power wire is probaly not hooked up to switched power. this will cause every thing to look good but not fire. the ignitor chip will send power (signal) to the coil but if the dont have power they wont spark. take a probe wire tester and poke threw the biggest wires going to the coils ( 1 per coil), they should have power when ever the key is in the on position. ( my earlier post was for a no crank situation)
good luck!
Old 02-25-2003, 02:02 PM   #14
SRKperformance
SRKperformance is an unknown quantity at this point
Send a message via AIM to SRKperformance Send a message via Yahoo to SRKperformance
make sure your battery terminals are clean and new. the simple sht got me. Mine woudnt cranck cus the starter woudnt fire thanks to a bad ground for the battery. Make sure the starter is wired properly.
SRKperformance is offline   Reply With Quote
Old 02-25-2003, 05:27 PM   #15
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
is the crank turning over or not?? Cause if it is, then your problem is most likely ignition.
Did you check to see if you're getting spark?? If you're getting spark, then the timing is off.
Are you sure you're getting fuel? You can pull a spark plug to see if it has some fuel on it.
AceInHole is offline   Reply With Quote
Old 02-27-2003, 12:21 PM   #16
gregsr20
gregsr20's Avatar
yes i am getting fuel, i hear the fuel pump, smell the fuel, pulled the line to see fue, injectors are pulsing, no spark to the coils, crank is turning, timing is off also, if the crank angle sensor is not in line properly and the timing is way off, will it send signal to the coils or not
Old 02-27-2003, 12:24 PM   #17
gregsr20
gregsr20's Avatar
also has any one done this swap from a ka24de auto to an s13 manual, when the harnesess were rewired what plugs by the fuse/relay box near battery location not used, i am also having trouble there
Old 02-27-2003, 12:34 PM   #18
SRKperformance
how did you check if your ignitor chip is working??? it sounds like ignitor chip to me. Also double check your CAS is it in the right place lined up properly timing wise. You need to take the valve cover off and check if it is lined up with the mark on the tip of the cas gear. There are two lines a orange one and a metalic indentation they need to be lined up go to www.srswap.com to FAQ and check CAS section it has a good description of what to look for. Also if you have any buddies with srs try using one of their ignitor chips and see if it fires. Also is the little red led light on the ecu lighting up if not your not getting ecu power. check these things out and then come back
Old 02-27-2003, 03:12 PM   #19
gregsr20
gregsr20's Avatar
my ecu lights up, i used an ignitor chip from my moms 92 infinti q45, pretty convienent, same results
Old 02-27-2003, 04:00 PM   #20
AceInHole
Autox Technician
AceInHole's Avatar
if the timing is way off, then you the engine wouldn't crank, but it should occasionally shudder. set everything to TDC to make sure everything is in the right position and go from there.
although, if you're not getting spark at all, the problem probably isn't timing.
Old 02-27-2003, 04:49 PM   #21
SRKperformance
how did you check for spark, make sure its dark so you can see if it sparks. Are you sure your getting fuel, is your gas tank empty? haha , check your fuses again. ALso check under the dash for a igniton start signal fuse take it out and play with the throttle as you crank, somtimes the motors dont like cold starts.
Old 03-01-2003, 01:01 PM   #22
gregsr20
gregsr20's Avatar
hey it is a bad ignitor chip, thanks for the help
