Old 05-20-2008, 12:08 PM   #1
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
how to check timing
can someone tell me or show me a link that shows how to check timing on a s13 sr20det blacktop? the only thing i know is you need a timing gun. i never did it because the tape on my cas is not ripped. i dont understand the fsm.
moses is offline   Reply With Quote
Old 05-20-2008, 09:14 PM   #2
SR2Zero
SR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really nice
Get a timing light and connect a spark plug wire from the coilpack to the spark plug. Clamp the timing gun onto the wire running to the coilpack. Cylinder numero uno, closest to the front.
http://www.frsport.com/How-To-Set-Cr...gine_t_25.html
If you need help from here, try to be kind of specific on what's confusing you. PM me if you have to.
SR2Zero is offline   Reply With Quote
Old 05-20-2008, 10:01 PM   #3
moses
which wire of the three do i clamp the timing light to
Old 05-20-2008, 11:41 PM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
timing light connect to battery..... connect the sparkplug wire connector to #1 cylinder.. start the car aim towards the crank.. there should be a pin sticking out from the front cover towards the crank pulley... notches signify degree's advanced or retarded.... if u want to adjust timing.... then u need some extra tools...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-21-2008, 03:11 AM   #5
all stock
all stock is on the path to ruinall stock is on the path to ruin
the red mark should represent 0, each additional white mark represents 5 degrees btdc, oem is 15btdc for sr i believe.
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 06-02-2008, 09:45 AM   #6
s13silviaboy
s13silviaboy is an unknown quantity at this point
how would you fix the timing if it is off? adjust the CAS?
s13silviaboy is offline   Reply With Quote
Old 06-02-2008, 10:10 AM   #7
Style
Style's Avatar
Style is on the path to ruinStyle is on the path to ruin
yeah loosen the cas bolts and turn the cas while engine running and ajdust the timing to what you want it to be and then tighten bolts.
Style is offline   Reply With Quote
Old 06-02-2008, 10:16 AM   #8
!Zar!
!Zar!'s Avatar
Whatever happened to disconnecting the tps.
Old 06-02-2008, 10:23 AM   #9
Ninjabread
Ninjabread's Avatar
^^Yep.
You're supposed to get the motor up to temp
Disconnect the TPS
check timing, set to 15* if it's an sr
reconnect tps.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
