Old 05-22-2008, 10:32 AM   #1
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
Another VLSD question
I know this stuff has been covered to death - but I've been searching and can't find a solid answer. I've killed my 180sx vlsd / axles after many miles of abuse (70k+) and i need a replacement. There is clicking from the rear at lower speeds / under load and maaaad play in the diff. Also diff doesn't lock anymore *at all* except randomly in the rain. Trying to figure out what to get.
I got a few questions:
1) Will Z32 Axles fit a stock S14 (with Z32 vlsd of course) or do I need J30 axles?
2) What's the difference between Z32 and J30 axles?
3) What is the gear ratio on a R33 VLSD. I've heard GT-R = 4.11, GTS = 4.36. Dunno if that's correct?
4) ECR33 is GTS and BNR33 is GTR, correct?
5) apparently the r33 vlsd I'm looking at is from a car that had an RB25DET. Were there non-GTR cars that had the DET? would that mean that it has a 4.11 rear or 4.36?
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 05-22-2008, 11:44 AM   #2
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
I don't know about the other stuff but the r33 gts-t diff/axles are direct bolt ons for the s14. In fact you won't even have to change your driveshaft in non vlsd/abs s14's because the diff doesn't have that abs sensor. 4.36 is the right gear ratio iirc. The 5 bolt axles are a better stronger design too. I like this set up in my car. It should bolt up into an s13 if you get the mounting hardware from an s14 and change the rear cover which btw is identical to the s14 cover.
Hope I helped a little.
-Retired
98s14inaz is offline   Reply With Quote
Old 05-22-2008, 11:59 AM   #3
DaPCWiz
DaPCWiz's Avatar
What's your setup?
N/A KA?
how's your RPMs @ 75 mph?
is 4.36 noticeably different from 4.08 (stock)?
Old 05-22-2008, 12:00 PM   #4
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
1) Will Z32 Axles fit a stock S14 (with Z32 vlsd of course) or do I need J30 axles? A Z32 Non Turbo LSD/Axles will fit fine.
3) What is the gear ratio on a R33 VLSD. I've heard GT-R = 4.11, GTS = 4.36. Dunno if that's correct? A Manual non GT-R is a 4.08 same as S14
4) ECR33 is GTS and BNR33 is GTR, correct? BCNR33
5) apparently the r33 vlsd I'm looking at is from a car that had an RB25DET. Were there non-GTR cars that had the DET? would that mean that it has a 4.11 rear or 4.36? 4.08
I just added after the questions
slidingsky is offline   Reply With Quote
Old 05-22-2008, 12:22 PM   #5
98s14inaz
Where did you find your data? I may have been misinformed on the gear ratio.
-Retired
Old 05-22-2008, 12:30 PM   #6
slidingsky
slidingsky's Avatar
I've dealt with over 200 LSDs in the past 2 years.
Old 05-22-2008, 12:32 PM   #7
98s14inaz
Don't take offense but there are a lot of other sources saying otherwise.
-Retired
Old 05-22-2008, 12:34 PM   #8
slidingsky
slidingsky's Avatar
PM'd hope that helps.
Old 05-22-2008, 02:04 PM   #9
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
http://ka24development.com/vlsd.html will help with some of your questions
WheelsDirty
Old 05-22-2008, 02:20 PM   #10
DaPCWiz
DaPCWiz's Avatar
yeah looked at that already... doesn't answer everything. Anywho.. ended up ordering an R33 w/ axles. I'm set... this thread can be closed. The folks over at jhot were very helpful with explaining everything to me and the ordering process.
Old 05-22-2008, 02:47 PM   #11
projectRDM
projectRDM's Avatar
Z32 axles do NOT fit. They're too long. That needs to be added so the next search run won't be misled.
FORMERLY R240NA
Old 05-22-2008, 02:52 PM   #12
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
its so sad that people dont search, there's 3 threads going on right now about z32 axles/hubs. Its very clear in the thread in which you hammered me haha.
http://www.zilvia.net/f/showthread.p...88#post1878288
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-22-2008, 09:06 PM   #13
projectRDM
projectRDM's Avatar
Axles aren't discussed much, not like hubs, but you're right, the info is out there, has been for years.
FORMERLY R240NA
Old 05-23-2008, 06:44 AM   #14
slidingsky
slidingsky's Avatar
Dang I didn't even realize I said axles.... I didn't mean to. I will go to my corner with a dunce cap now.
Old 05-23-2008, 06:46 AM   #15
DaPCWiz
DaPCWiz's Avatar
Dang I didn't even realize I axles.... I didn't mean to. I will go to my corner with a dunce cap now.
not to beat a dead horse, but just verifying your typo.... you are agreeing that z32 axles don't fit?
Old 05-23-2008, 08:24 AM   #16
98s14inaz
I've got the part #'s for the boots incase you get the desire to rebuild the r33 axles before you put them on your car. I did, I'm kinda anal about doing things once and being done with it.
-Retired
