Old 03-01-2003, 11:27 PM   #1
240sx2Nur
240sx2Nur is an unknown quantity at this point
KA Not reaching redline
I noticed after a few trials thats my car does not hit the redline (automatic transmission), rather it shifts at 6000rpm instead of 6500rpm. What can be the possible causes of this? How can it be fixed?
Nico
240sx2Nur is offline   Reply With Quote
Old 03-02-2003, 12:36 AM   #2
/etc/shadow
/etc/shadow is an unknown quantity at this point
Not sure if this free mod will increase the shift RPM, but it should help auto shifting in general:
2) Automatic transmissions ONLY: _On both s13 and s14 auto trannys, there is a circuit, that when broke, removes some fluid weight from the tranny and shifts faster and harder. _GTech meter shaved .2 seconds off.... but then again, GTech sucks. _This has been said by Nismo to not cause any harm, and said by people that anything harder is going to lead to broken stuff.
_ _ _How To: On the right side of the engine bay, near the strut tower, really close to the fender, there is a grey connector. _Unclip that. _There is only one, and yes, it is a pain to unclip. _Turn on your car, and drive away. _
Please note: This will cause an s14 check engine light to come on. _Read the FAQ about ecu resetting to clear the code.
http://www.zilvia.net/f/showthread.p...923#post205923
/etc/shadow is offline   Reply With Quote
Old 03-02-2003, 01:12 AM   #3
AKADriver
AKADriver's Avatar
That connector is for the dropping resistor for the transmission fluid pressure regulator. Unplugging it increases transmission fluid pressure, which leads to harder, faster shifts.
But the upshift RPM isn't regulated by fluid pressure. In these cars it's regulated by the automatic transmission's computer.
6000rpm is a pretty good shift point, actually, considering the KA's stock powerband. But barring that... If you want the car to go to redline, shift it manually.
Old 03-02-2003, 02:57 PM   #4
240sx2Nur
Unplugging the regulator makes the transmission feel horrible, considering it already is a bit clunky. Behind the gas pedal there is a plastic piece. If removed will should increase pedal travel, correct? Are there any side effects to removing it?
Nico
Old 03-02-2003, 03:26 PM   #5
mrdirty
mrdirty is an unknown quantity at this point
broken throttle cable.
mrdirty is offline   Reply With Quote
Old 03-02-2003, 08:07 PM   #6
240sx2Nur
that only seems tangible if the stock slack has been taken up from the throttle cable.
Nico
Old 03-02-2003, 08:09 PM   #7
mrdirty
what?
Old 03-02-2003, 08:12 PM   #8
mrdirty
You should be @ WOT w/ the pedal fully depressed, if you're not you need to adjust. Pulling the throttle cable more will only spin the throttle plate back into the intake stream (therefore less than WOT).
You can't get the throttle body any more open then WOT.
Not that this would effect shift RPM anyway...
Old 03-03-2003, 02:29 PM   #9
240sx2Nur
The computer controls the shift points correct? Therefore possibly something to do with the codes may be faulty. How can I check for faulty codes?
Nico
Old 03-03-2003, 02:59 PM   #10
AKADriver
AKADriver's Avatar
Nothing is faulty! That's exactly what it's programmed to do!
Old 03-03-2003, 03:32 PM   #11
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
I hate to break this to you man, but your car has a truck engine in it. If you are shifting higher than 5500 rpm you are probably shifting too high. It makes its torque down low and its done by 6000 rpm. I have a manual and I don't shift higher than that, there isn't any point. The automatic computer is trying to shift at the optimal points for your car, and at redline isn' t optimal for acceleration or engine life, so it doesn't shift there. Sorry. Performance chip might let it go up higher, but like I said... no real benefit unless you are running cams or something that moved the power band towards redline.
andrave is offline   Reply With Quote
Old 03-03-2003, 03:49 PM   #12
GlacierFreeze
GlacierFreeze is an unknown quantity at this point
I'm sure there are a lot of ppl who could argue with you about that "truck engine" statement.
GlacierFreeze is offline   Reply With Quote
Old 03-03-2003, 05:18 PM   #13
mrdirty
Originally posted by andrave
I hate to break this to you man, but your car has a truck engine in it.....
you and your ignorance are going to make enemies fast here...
Old 03-03-2003, 06:23 PM   #14
240sx2Nur
Thanks for the help.
Nico
Old 03-03-2003, 07:43 PM   #15
andrave
andrave's Avatar
quote:
can you say "wah?"
do a little research mr blah, and check it out for yourself. Where did the handy little KA24 come from? Why does it make so much torque down low? oh, thats right. its a truck engine. flamers online are flamers in real life.
