Old 05-30-2008, 02:43 AM   #1
YoungGun
YoungGun's Avatar
SR : Weird surging problem
I had a boost leak at the bov flange because the gasket was paper thin. I put liquid gasket on and let it dry until the next morning. When I went to drive it the boost leak whine was gone, but then at high boost my turbo would surge. Tonight driving home I noticed if I slowly build boost the bov blows off correctly. Any input on what the problem could be? I want to fix this before my turbo seals give out again. Could it be that some sealer got into the air pocket for the bov?
Engine specs:
Redtop SR
3" turbo back
Intake
FMIC
1g DSM bov vented to atmosphere
YoungGun is offline   Reply With Quote
Old 05-30-2008, 03:39 AM   #2
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
it would surge under throttle?
or just when the bov is supposed to be working?
Need automotive work done in the antelope valley?
Ask me how i can help.
tt99ol is offline   Reply With Quote
Old 05-30-2008, 09:40 AM   #3
YoungGun
YoungGun's Avatar
It surges after I let off of WOT. Partial throttle under boost it blows off correctly.
Old 05-30-2008, 10:02 AM   #4
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
get a new bov
((sr)) kelly is offline   Reply With Quote
Old 05-30-2008, 01:40 PM   #5
YoungGun
YoungGun's Avatar
Any other suggestions?
Old 05-30-2008, 02:21 PM   #6
tt99ol
tt99ol's Avatar
how much boost are you running
and what vacuum source is the bov getting
Old 05-30-2008, 02:50 PM   #7
Forge_55b
Forge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enough
if nothing changed other then u putting on the gasket maker, try another bov is the only way i can think of to really check
oh and u probably didn't give enough time to let it cure completely
Forge_55b is offline   Reply With Quote
Old 05-30-2008, 03:08 PM   #8
YoungGun
YoungGun's Avatar
Stock boost, but it must be creeping some because of my exhaust I don't have a gauge to check. I have a t connector going from the intake manifold to the bov to the turbo wastegate like how it's supposed to be.
Well I gave it enough time to cure because it sealed it and took care of my boost leak issue. I guess i'll try to borrow another bov, I think i'm gonna just take it off and try to reseal it tonight and use less sealer?
If anyone has any other suggestions i'm all ears.
Thanks to those who have responded.
Old 05-30-2008, 03:21 PM   #9
kamikazekid
kamikazekid's Avatar
kamikazekid is making a name for him/her selfkamikazekid is making a name for him/her self
dont run the vacuum line fom the mani to the wastegate, run it from the pressure source (hot pipe/ cold pipe) witch ever. its surging because when you let off the throttle at high boost and the throttle plate closes, theres no more pressure to open the wastegate so it has no releif. remember the wastegate is actuated by pressure, bov actuated by vacuum. You get what im saying right?
Drifting is not a crime
kamikazekid is offline   Reply With Quote
Old 05-30-2008, 04:28 PM   #10
YoungGun
YoungGun's Avatar
Read what I wrote again, I have it set up correctly.
Old 05-30-2008, 04:33 PM   #11
kamikazekid
Im reading that you have the wastegate vacuum hose going to the mani correct? is the turbo internally actuated? stock turbo right? you can run that set up that you described but like you were saying if your exhast is choked you're gonna get some boost creep. nissan has it set up from the factory to have the pressure source running to the wastegate for a reason think about how the wastegate is gonna function when you put that vacuum hose behind the throttle plate. you said you were all Ears right? just try the set up i said its cheaper than a blow off valve. if it doesnt work than no big deal.
Old 05-30-2008, 04:39 PM   #12
YoungGun
YoungGun's Avatar
Yeah stock turbo there a line that goes from the intake manifold then t's off. One line goes to the bov and the other line goes to the wastegate, the setup isnt my problem. I'm thinking that the bov is messed up now.
Old 05-30-2008, 04:44 PM   #13
kafanylovesme
kafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfection
Send a message via AIM to kafanylovesme
CS solves all problems...
Wish I could help Cody, but compressor surge ftw!
Originally Posted by PHLIP View Post
Fuck, I wouldn't let 30 year old seasoned veterans drive my car to the grocery store a quarter mile from my house, let alone a young/dumb/full-of-cum teenager.
kafanylovesme is offline   Reply With Quote
Old 05-30-2008, 04:46 PM   #14
kamikazekid
im just saying try that setup first, just a suggestion but the way you have the vacuum lines set up is incorrect. you need to run the pressure side to the wastegate. when you run it to the mani and the throttle closes it creates vacuum witch will not open the wastegate. people run your setup yes but its not a good idea for hard driving ,on off throttle situations. you will get boost creep.
Old 05-30-2008, 04:59 PM   #15
YoungGun
YoungGun's Avatar
lol CS! no man at least not for me whenever I surge smoke comes out of the exhaust! lol
pm'ed you.
Old 05-30-2008, 05:17 PM   #16
tt99ol
tt99ol's Avatar
wastegate should always have its own source
always
the bov should be t'd in with the fpr
what kamikaze is trying to say is to run your wastegate from a nipple on the hotpipe
or coldpipe
it will keep the wastegate open until the bov relieves all pressure this way
running it from the mani gives you more boost
it also slams the wastegate shut on throttle lifts causing a spike
just try it and see if it works
Old 05-30-2008, 05:27 PM   #17
kamikazekid
always
or coldpipe
thanks brotha.
good luck with the surge hope we could help.
Old 05-30-2008, 10:38 PM   #18
((sr)) kelly
im going to be selling my HKS ver 2 bov/hot pipe kit from enjkuku soon... lmk if you are interested. Pull type bovs FTW
Old 05-31-2008, 01:13 AM   #19
YoungGun
YoungGun's Avatar
Ungh, YOU GUYS! I have the bov on the hotpipe! my friend is going to lend me his greddy rs, i'll see if the bov is faulty or not.
Old 05-31-2008, 11:25 AM   #20
jonathan12uiz
jonathan12uiz is an unknown quantity at this point
Send a message via AIM to jonathan12uiz Send a message via MSN to jonathan12uiz Send a message via Yahoo to jonathan12uiz
what I was wondering from your post is...
1.Is your BOV recirculated?
-I've driven a few SR's and non-recirculated BOVs with no Fuel controller seem to have this surge/skip/bogging slightly after a shift because the air that was calculated through the maf was released. Now this is not valid if you are running a blowthru setup on your maf.
2.What are your vac lines routed like. Redtop sr is...
the top left on the throttle body goes to the FPR. This is also where you can T for a Boost gauge.
the top right (larger diameter one) goes to the BOV. Make the line as short as possible.
and the bottom vac nipple is usless, just cap it off.
Now for the wastegate you have to have a line coming off your hotpipe straight to your wastegate (line as short as possible). If your hotpipe didn't come with a nipple for this, just go to home depot or lowes and go to the plumming section. buy a brass threaded nipple that can fit a vac line. Drill a hole in your hotpipe. tap the hole to fit the threads of your new nipple. insert your nipple and jb weld it. run your vac line and VOILA! done.
3. Timing is 15* advanced right?
-Timing plays a good role in a lot of weird problems.
Lemme know.
jonathan12uiz is offline   Reply With Quote
Old 06-01-2008, 12:15 AM   #21
YoungGun
YoungGun's Avatar
Uhhh not sure what your description of the vacuum routing is but anyways I FIXED IT! yay i'm so happy, never going to touch my engine again. Stock SR FTW.
Oh those who are wondering, I put too much liquid gasket shit on and it got in this little hole which I guess prevented it from blowing off? Well I scraped it off and now it works. No boost leak, no surging, OKAY!
Old 06-01-2008, 12:17 AM   #22
kafanylovesme
Nice! Good to see you fixed it Cody!
Now I have a problem of my own =/
Griffith Park owned my intercooler and piping today!
