Old 06-02-2008, 05:56 PM   #1
dingwing
dingwing is an unknown quantity at this point
SR camshaft question?
hello everyone, im trying to help my friend put back togther his sr. i dont really know much about motors. i wanted to know how do you know if you put the camshafts back in right and what will happen if they are not in right?
dingwing is offline   Reply With Quote
Old 06-02-2008, 06:40 PM   #2
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
you follow the fsm. it's pretty hard to screw up.
aNskY is offline   Reply With Quote
Old 06-02-2008, 08:30 PM   #3
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
theres these tabs on the ends of the cams... its where u bolt up the cam sprockets... the longer the tab... signifies if its the one used for the exhaust side because of the dizzy..
chances are if you dont align the cam sprockets right... with the timing chain markings and piston #1 to TDC.... starting it up you might not even run... or you could bend a valve...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-02-2008, 09:57 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You cant fuck up putting on the cams, what you can fuck up on is the mechanical timing and you bending the fucking valves if theyre off.
Not sure how much of the engine is apart or put back together but I'd start from scratch and follow the FSM. Make sure the bottom end is at TDC, double check the chain and make sure the marks are where theyre supposed to be. If those 2 are good, then putting the cams on and re-aligning the marks with the use of the chain marks is gonna be cake.
CLICK HERE!!!
Old 06-03-2008, 11:32 PM   #5
infinitexsound
you use cake as much as i use cake... lets go get some cake....
