Old 06-03-2008, 03:10 PM   #1
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
How To- Install XPEL Headlight Film on S14 Kouki
Alright guys, time for my 2nd writeup... Installed Xpel headlight protection on my kouki and took a bunch of pics so i figured I'd do a lil writeup, so here goes.
1. Layed out the film, tested it for cut and fitment, its perfect. As with any film, prep work is key, so i went over the headlights first with soap & water, then with a razor blade, then with solvent, then with a scrubbing pad, and finally buffed them with compound. They were PERFECTLY clean when done.
2. Heated it up, set the Wagner gun on 1150* F till it got quite flexible. This shit is 40mil thick which is frickin Ridick! you can barely bend it when its cold, its really thick, but thats good. According to their website it can withstand a 1cm diameter rock at 60mph with no damage at all.
3. Then we sprayed the headlights and our hands with the water/baby shampoo solution. Even though the website says to use water and alcohol, my friend who has tinted many windows, prefers this solution because its a bit sliperey'er so we could move it around better. Then peeled the backing off and soaked it with the solution as well. Lined it up with my friend, left 1/8" in on all sides, it fit awesome i must say.
4. Once its lined up, I held it in place whil my friend used the squegie to scrape away the solution and get it to stick in place. What you want to do is line it up as good as you can, and scrape it on the flattest part. Then once its stuck and linedup, we rinsed the rest of the solution away with pure water and then continued to squeegy.
5. Then you wanna wrap the squeegy in a paper towel (preferably lint free) and go over it finely using the heat gun to mold it into place. The headlights themselves were easy compared to the compound curves in the fogs....
6. Okay done with one headlight, didnt make a huge difference on light output, i think they look sweet though.
*7.* Important step* Now on to the dreaded corners.... Start by curving the piece with backing still on it around the corner, and heat it to mold to shape. Once its following the natural curve, let it cool and it will be much easier to work with. I also noticed that the light came out on the outtermost points of the corners, but on the inner part where it meets with the headlight it has a black void of light about 3/8" thick. So in order to make it look good with no white border light coming off the edges, i lined it up as close to the outside edge first as possible, and bent it around the corner to the front where it had some leeway. You can see in this pic how close it is to the edge.
8. Repeat same steps above, only going slower, and with lots more heat this time. I made sure to seal first on the outter flat parts, and then work my way around.
Again use lots of heat and go slow, making sure to push the water out evenly. Another Baller tip, if you look close the kouki corner had a crease in the middle of it, so with a very strong or hard squeegy wrap a towell around it and wet the outside so you dont tear or poke through the Xpel, and push it out. With enough heat and time it will seal up nicely and sit flush with it.
You can see here how its wanting to pucker out, heat and time (dont rush) will fix this.
And there ya go, she's all done
Took about 1.5 hrs from start to finish. I love how they look, and light output didnt decrease very much.
So what do ya'll think?
INeedNewTires is offline   Reply With Quote
Old 06-03-2008, 03:14 PM   #2
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
looks pretty cool to me!!
+1 to you man
HS13KLS is offline   Reply With Quote
Old 06-03-2008, 03:15 PM   #3
murda-c
murda-c's Avatar
Now it looks like a zenki that's been in the sun since 95...
haha jk man looks ok
Old 06-03-2008, 03:21 PM   #4
jrbump
jrbump's Avatar
jrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond repute
Does it come in clear or only in "urine"?
jrbump is offline   Reply With Quote
Old 06-03-2008, 03:21 PM   #5
stiizy
stiizy's Avatar
^ clear,blue,yellow,smoke, and maybe other colors
nice i had the rockblocker ones on my car..
Old 06-03-2008, 03:23 PM   #6
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
not my style, but honestly, it looks pretty good on your car.
kensreliableb18b is offline   Reply With Quote
Old 06-03-2008, 03:25 PM   #7
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
I like it. Although if you wanted yellow headlights I would have traded you my zenki's lol
-Retired
98s14inaz is offline   Reply With Quote
Old 06-03-2008, 03:32 PM   #8
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
i think it looks really good but maybe a diff. color none the less great write up
1989rps13 is offline   Reply With Quote
Old 06-03-2008, 03:35 PM   #9
INeedNewTires
comes in lots of colors n stuff, I got it from Enjuku Racing for a bit cheaper than from the dealer, plus wanted to help out a more nissan specific enthusiast shop, than a general manufacturer. Heres the direct link
http://www.xpel.com/products/headlig...&submodel=1262
Thanks for the compliments and reps guys!
Old 06-03-2008, 04:44 PM   #10
INeedNewTires
Where i got em
http://enjukuracing.com/xpel-headlam...tml?cPath=2_97
Old 06-03-2008, 04:57 PM   #11
ROUGE180
ROUGE180's Avatar
ROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfection
Send a message via AIM to ROUGE180 Send a message via Yahoo to ROUGE180
Cool man. Nice write up. Functional and stylish at the same time. I went to the dealer site. Seems like they have a pretty good selection. They also have film for S13 and S15. Thought that was pretty cool.
EDIT: They have it for Silvia's only. No pop-ups
ROUGE180 is offline   Reply With Quote
Old 06-03-2008, 05:05 PM   #12
240drifter1
240drifter1's Avatar
240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute
Send a message via AIM to 240drifter1
Fuck man.
That looks awesome, I plan on doing that or smoked on mine.
240drifter1 is offline   Reply With Quote
Old 06-03-2008, 05:43 PM   #13
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
i like the yellow headlight look, i did it to my coupe but with krylon glass stain paint.
PEGASUS
nismo racer is offline   Reply With Quote
Old 06-03-2008, 05:44 PM   #14
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
Lamin-X is also the same shit, Honda guys have been jocking this for awhile. Not to say there were others first, but I'm only into Nissan/Honda so...
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 06-07-2008, 08:41 AM   #15
SMOKE'N'TYRES
SMOKE'N'TYRES is an unknown quantity at this point
I will say this, they look better when the car is moving.
SMOKE'N'TYRES is offline   Reply With Quote
Old 06-07-2008, 04:01 PM   #16
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Great DIY with pics but not my cup of tea !!
WoolyS14DET is offline   Reply With Quote
Old 06-07-2008, 04:52 PM   #17
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
cool write up.
I CAN FLASH MODIFY YOUR XBOX 360.
Modrified is offline   Reply With Quote
Old 06-07-2008, 05:31 PM   #18
jackjack
jackjack's Avatar
not bad.... not bad......
i dig it.
