Old 06-05-2008, 03:03 PM   #1
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
J30 Drivershaft Swap??????
I did a few quick searches and found nothing.
Will the J30 ABS Driveshaft swap into the S14 chassis?
**I have a factory R200 LSD from an ABS model S14 already installed on my S14. I'm getting a weird rotational clunking lately (after having the R200 on there for about 2 years).
**I have been told that the bearing int the driveshaft may have gone bad due to extra stress from having that extra 3 inches of length on the ABS Differential.
**This may be B.S. but I fig if a J30 DShaft would swap over this would be a cheap fix since the DShaft seems pretty difficult to find from the ABS equipped S14's.
And the One Piece Shafts are just so pricey
Any info would be great!!!!
The Chad is offline   Reply With Quote
Old 06-05-2008, 04:58 PM   #2
projectRDM
projectRDM's Avatar
If it fit you'd already know about it.
It doesn't, it's too long.
And FYI, there's no extra 'three inches' on an ABS diff, it's about 1.5 inches at best.
FORMERLY R240NA
Old 06-05-2008, 05:20 PM   #3
The Chad
The Chad's Avatar
^^ Fine Fine I was hoping that since the rear end swapped over the shaft might too.
--And i haven't been under the diff about 2 years so I didn't remember how much longer, just that it was longer...sorry.
Does anyone have any input as to what may be causing the rotational clunking?? Or should I just have a one piece fabbed up?
Old 06-05-2008, 09:34 PM   #4
projectRDM
projectRDM's Avatar
Driveline variations from the engine mounts, transmision, etc all have an effect on driveshaft fitment. Some people can get away with it, others notice a grinding right away as the shaft is jammed too tight against the transmission. You can try loosening and readjusting everything from crossmember, engine mounts, transmission mount, subframe, etc. to give a little more room.
FORMERLY R240NA
Old 06-06-2008, 06:02 AM   #5
The Chad
The Chad's Avatar
Yeah i might just do that. Shame though, I just finished putingthe motor and tranny in not too long ago. I swapped in NISMO motor and tranny mounts.
