Old 06-09-2008, 11:03 AM   #1
mickeymoose
mickeymoose is an unknown quantity at this point
Question Electrical Problems with 240 SX
okay I have a 1993 240 SX.I have had the car since new. I am having a issue with Alternater not charging the battery. The battery is new and I have replaced the Alternater with a new one. When I saw the battery was still not charging I went back to the shop and had them test the old Alt just to find out it was good all along. The Alt relay 75v appears to be fine. Is this possibly a ignition switch problem? I have had issues with it in the past. I would hate to go buy a new one and that wasan't the problem and then of course I coudn't return it. Thanks for any assistance
mickeymoose is offline   Reply With Quote
Old 06-09-2008, 11:06 AM   #2
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
check your ground. go from there.
SexPanda is offline   Reply With Quote
Old 06-09-2008, 11:11 AM   #3
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
check the ground under the fusebox in the engine bay i cut mine and solder in a longer piece of wire and grounded it where my cruise control use to mount(the back of the passenger side strut tower) works fine now. both the brake the and battery light went away -los
los_inc is offline   Reply With Quote
Old 06-09-2008, 11:14 AM   #4
mickeymoose
Thanks for such a quick reply. I have checked the ground and all are well .
It appears no power is going to the alt.Somewhere in the circle of electricity something is wrong. Maybe the ignition switch, fuse, relay,bad wire? but I'm really not sure. I appreciate your comments and Help.
Old 06-09-2008, 11:17 AM   #5
los_inc
los_inc's Avatar
how did you check your grounds? i hope you used a multimeter cuz a visual inspection isn't gonna do shit for good measure i'd disconnect each one and hit with a wire brush or piece of sand paper don't be a lazy Floridian DO IT!!!!! -los
Old 06-09-2008, 11:18 AM   #6
mickeymoose
also forgot to note this as well. When I turned off the key switch for the Ignition, the check Engine,Brake and belt lights actually come on. I have to turn the key back and forth several times to make them turn off.This just started happening when the other problem arose. I think maybe there connected.
Old 06-09-2008, 11:18 AM   #7
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
this happened to me when the insulator broke other than that make sure your wires connecting to the terminal in the back arent broken i had that problem too
jorge1190 is offline   Reply With Quote
Old 06-09-2008, 01:24 PM   #8
projectRDM
projectRDM's Avatar
There's also a 5A fuse for the alternator under the hood, check it. It powers the regulator inside, if it's blown the alternator won't do a thing.
FORMERLY R240NA
Old 06-09-2008, 11:15 PM   #9
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
the problem's in your lower harness.
check all the connectors that go to your fuse box, if you don't up and see anything unplugged then look for a square reddish plug. in it you'll find a white wire with a red stripe. turn your car on (start your car) and try giving that wire battery voltage. you can strip a little sheathing off it and run a jumper wire to it aka twist your jumper wire onto the part you stripped then take the other end of the jumper wire and touch it to the battery's positive terminal. if that doesn't kick on your alternator then you need to look deeper into the lower harness for loose wires/other issues.
the problem is therein
if your alternator kicks on after you give it some battery juice then post back the update and we'll go from there
good luck
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 06-10-2008, 08:11 AM   #10
mickeymoose
Thanks, I'll give those all a try and get back. Really appreciate the assistance.
Old 06-10-2008, 08:18 AM   #11
SleeperSx
SleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choices
If nothing else By pass the harness going to the fuse box, Make up a wire 8 gage will work from the alternator to the battery, Make sure you put a fuse link in between. But this will fix a wiring problem.
SleeperSx is offline   Reply With Quote
Old 07-23-2008, 05:56 PM   #12
xturboexpress
xturboexpress has made poor choicesxturboexpress has made poor choicesxturboexpress has made poor choicesxturboexpress has made poor choicesxturboexpress has made poor choicesxturboexpress has made poor choicesxturboexpress has made poor choices
xturboexpress is offline   Reply With Quote
