Old 06-09-2008, 01:13 PM   #1
digitalightkenz
digitalightkenz will become famous soon enoughdigitalightkenz will become famous soon enoughdigitalightkenz will become famous soon enoughdigitalightkenz will become famous soon enough
s13 WTB T25 Turbo TODAY! NEEDED TO GET MY DAILY DRIVER RUNNING
So I think my oil seals from my turbo gave out. So I need a new turbo, or rebuild mine, whichever is cheaper.
I think and believe that its my oil seals, because when I opened my intercooler piping, there was oil. And it smokes white
It's a T25 turbo.
I am located in the 323/626 area. Willing to pick up within 70 miles.
I have money at hand.
Basically I will buy any turbo that is in good condition and can fit my hotside of my turbo,
Could anyone please help me out?
Does anyone know if a T28 would fit bolts on?
pics would be greatly appreciated.
Ken
Ps. Since I need it bad BAD. here is my number 626-757-8427. I need it to get my DD up and running.
Ken.
digitalightkenz is offline   Reply With Quote
Old 06-09-2008, 01:38 PM   #2
180Sil
180Sil will become famous soon enough180Sil will become famous soon enough180Sil will become famous soon enough180Sil will become famous soon enough
too bad i'm on the east coast, i have 2x t25 for sale. t28 would fit but you need to rotate the piping
180Sil is offline   Reply With Quote
Old 06-09-2008, 01:52 PM   #3
rb25jun
rb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the rough
Send a message via AIM to rb25jun
wrong section
rb25jun is offline   Reply With Quote
Old 06-09-2008, 01:54 PM   #4
k's_silvia2.0
k's_silvia2.0's Avatar
k's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfection
Send a message via AIM to k's_silvia2.0
It's a T25 turbo.
Ken
Pm sent to you.
k's_silvia2.0 is offline   Reply With Quote
Old 06-09-2008, 02:11 PM   #5
digitalightkenz
Originally Posted by rb25jun View Post
wrong section
I am so sorry, where am I suppose to post this?
SOrry, sorry.
Guys, do you gyus think its the oil seals from the turbo? It has to be right? I am kinda lost and need some guidance. Basically it smokes a lot when I started it ( its white smoke ). And I see a little of oil leak between the hot-side and the downpipe. I see it leak oil. Does this mean that I need the new turbo? yeah right? Kinda lost....
KEn
Ken.
Old 06-09-2008, 02:29 PM   #6
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
i am almost sure your turbo seals are blown, i installed my t25 that i bought, and i thought it was fine, there was shaft play but mininal. installed it and smoke came out right away, on first startup it was running rich, then tuned it properly and it ran fine. but i couldnt drive it, when it boost a little the car stalls and turns off, i removed the turbo, and found out there was oil everywhere in the turbo elbow, since i dont have my downpipe or exhaust on, and i removed the turbo inlet and outlet and there was oil in the turbo, and the shaftplay went crazy, now theres in and out, and side to side play. wow? i took the turbo off, borrowed a friends turbo with the same setup, and it ran fine, i can fully boost and run the car now. i still dont have my downpipe or exhaust on, i need to bring it to an exhaust shop. =/
well heres a video of my car smoking. i hope that helped =P
[ame]http://www.youtube.com/watch?v=Bpl-An0wA8Y[/ame]
jinesz32 is offline   Reply With Quote
Old 06-09-2008, 02:49 PM   #7
digitalightkenz
Thumbs up
Thank you so much for the info! Now, I have a question, my wastegate is external, and I think that the wastegate comes internally. So How would I know how to block it off so I can use my external wastegate?
ok. So I need to get a new turbo, I am pretty sure that is my problem, It smokes from the same place from the engine. But my exhaust smokes white as well. Same thing, close to the turbo. Between the turbo hotside and the downpipe. so want to change it, but even if I change it, How would I change the wastegate?
Need help >.<
Ken.
Old 06-09-2008, 03:36 PM   #8
jinesz32
jinesz32's Avatar
i havent really checked anything about the wastegate yet so i woulnd't know, all i know is the t25 i have has a t28 wastegate on it the one that blew oh well. =P
well good luck bud.
Old 06-09-2008, 03:48 PM   #9
digitalightkenz
wrong section
fixed it! =-p
http://www.zilvia.net/f/showthread.php?t=196970
Please could someone tell me if most T25's come with external or internal wastegate? and if it comes with an internal wastegate, how do you block it off.
please provide with pics =-p
Ken
Ken.
Old 06-09-2008, 03:50 PM   #10
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
they come with an internal wastegate. you block it off by welding the flapper shut in the exhaust housing. easily done.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 06-09-2008, 04:08 PM   #11
cyclone92692
cyclone92692 is a well-known jackass
i have a t25 turbo for sale great condition i live in the O.C let me know if you want it. no games, no jumk. good condition or call me 949 278 5241
cyclone92692 is offline   Reply With Quote
Old 06-10-2008, 09:39 AM   #12
digitalightkenz
ill call you later. So no oil leaks? no shaft play?
I live in LA. And need the turbo ASAP.
Ken
Ken.
Old 06-13-2008, 10:30 PM   #13
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
t25 come with internal waste gate.
if you want to block them you weld them shut. or you can buy those block off plates but i dont think they work reallie best off just welding it shut.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
