Old 06-17-2008, 09:44 PM   #1
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
California Smog/Emissions Test Failure, High HC
I'm in California, so you guys here will know the drill. I'm a test-only bitch of the state, and so I'm kind of limited in my options here. As I'm also limited in funds for sending it to a Test and Repair shop, I thought I'd come here first.
Here's the gist: 1990 Nissan 240sx, swapped SOHC for a 91' KA24DE. Roughly 200k miles on the clock (didn't write down from donor car).
What I have, asterisk (*) indicates new since failure
New Catalytic Converter
*New Spark Plugs (NGK Platinum, properly gapped)
*New Plug Wires (Bosch, I know, I know...)
New Rotor and Cap
*New Injector O-Rings (Nissan OEM, not 3rd party)
Injectors all test within spec
Compression 149 +/- 2 across the board
Not burning any oil that I can detect
Timing set 15 degrees BTDC as I heard that helps with HC.
I was told I had a slight misfire at idle, which is why I've changed the above components. Now, for the numbers
@idle (650 per fsm)
%CO2 14.9 (Pass)
%02 0.2 (Pass)
HC PPM 169 / MAX=120 (FAIL)
%CO .11 / MAX=1.0 (Pass)
@2500~RPM
%CO2 14.7 (Pass)
%02 0.3 (Pass)
HC PPM 72 / MAX=140 (Pass)
%CO .37 / MAX=1.0 (Pass)
So... any ideas?
Prime is offline   Reply With Quote
Old 06-17-2008, 09:50 PM   #2
Thursday
Thursday's Avatar
Thursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfection
Send a message via AIM to Thursday
cat msglngth
Thursday is offline   Reply With Quote
Old 06-17-2008, 09:52 PM   #3
drftem
drftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the rough
whats your idle set at and what is your timing set at at idle?
drftem is offline   Reply With Quote
Old 06-17-2008, 09:52 PM   #4
drftem
and did you heat up the cat alot before taking it there?
Old 06-17-2008, 09:57 PM   #5
Prime
Prime's Avatar
Idle as 650 as it says above, editing to show timing @ 15 degrees BTDC,
and drove it 20 miles in 4th gear to get to the test site, cat was smoking hot.
Old 06-17-2008, 10:01 PM   #6
Prime
Prime's Avatar
Originally Posted by Thursday View Post
cat msglngth
Cat is new, like I said. I -really- doubt it would be the cat. Thing doesn't even have an oil change on it.
Old 06-17-2008, 10:41 PM   #7
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
Check the timing. Some of these smog guys mess w/ the timing to get the car to pass. PM prime i can help you out with this.
zylvia213 is offline   Reply With Quote
Old 06-17-2008, 10:45 PM   #8
Oo_Skyline_oO
Oo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud of
Send a message via AIM to Oo_Skyline_oO
check your egr valves and vacum hoses, those are very tempermental, if those are bad, very good chance you wont pass.
Oo_Skyline_oO is offline   Reply With Quote
Old 06-17-2008, 11:50 PM   #9
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
go to advance autoparts to get guarenteed to pass emission formula. worked for me.
reccakun08 is offline   Reply With Quote
Old 06-18-2008, 01:55 AM   #10
Prime
Prime's Avatar
Will do.
Alright, I'll give a look. I just replaced those last year when I swapped the motor over, but no harm in checking.
I've seen that stuff, but always felt kind of wary about it... I've got the time, so I guess it couldn't hurt. I'll think about it.
Old 06-18-2008, 03:07 AM   #11
idlafie
idlafie's Avatar
Check out my response from a previous thread.....
http://www.zilvia.net/f/showthread.p...highlight=smog
Put your ECU into Diagnostic Mode & check for any trouble codes. Make sure your Engine Coolant Temperature sensor is working along with your Oxygen sensor. Also check the small vacuum line under the BPT valve. It's "L" shaped and usually cracks causing a loss of vacuum to the EGR valve.
Hope it helps...
ID
EDIT:
Damn CARB!!!...they went & changed the link on me!!!....this is the CORRECT CARB link....
http://www.bar.ca.gov/80_BARResource..._Glossary.html
Old 06-18-2008, 03:33 AM   #12
Prime
Prime's Avatar
Hope it helps...
ID
EDIT:
Code 55, all clear. Did that earlier today. That specific vacuum line was cracked a month or two ago, I replaced it. Will check again. 02 and CTS are both under 3 months old and tested good when installed, but again, I can check. Haven't looked at your links yet, will do in the morning when I get up for work.
Thanks again, to everyone really.
Old 06-18-2008, 12:14 PM   #13
techn9ne
techn9ne's Avatar
techn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the rough
Send a message via AIM to techn9ne
for an easy fix, create a small, not very noticeable vacuum leak. since you are not in an enhanced area, you dont need a dyno test, and NOx is not measured. just make sure its hard to find.
techn9ne is offline   Reply With Quote
Old 06-18-2008, 12:20 PM   #14
DohcKA
DohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfectionDohcKA is close to perfection
use a bottle of sky blue
DohcKA is offline   Reply With Quote
Old 06-19-2008, 01:05 AM   #15
Prime
Prime's Avatar
Assuming extra air in the intake mixture, kills HC? Hm... could just get a T fitting, leave one end open at the back of the motor maybe... Good idea, lemme do some tinkering...
Sky blue? Never heard of it. I've done the Seafoam thing before, but this is new to me.
Old 06-19-2008, 01:08 AM   #16
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
sky blue... as in vodka?
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 06-19-2008, 01:12 AM   #17
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
Oh yeah, full your take up like, 3/4 the way, then pour in some everclear...
Seriously, get some uh...
Seafoam. Thats it. couldnt think of the name. It'll clean up your engine real good like, tell you what boy.
SexPanda is offline   Reply With Quote
Old 09-13-2008, 03:09 AM   #18
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
how much money are you going to have laying around to pass this smog?
handinpants is offline   Reply With Quote
Old 09-13-2008, 08:05 PM   #19
Lucient
Lucient is making a name for him/her selfLucient is making a name for him/her selfLucient is making a name for him/her self
Use a quart of denatured alcohol. Search around the net. This stuff works. My car failed the sniffer horribly and with the alcohol I passed with flying colors with no cat. I repeat with no cat. I have several friends that have passed with their SR and RB powered cars with no cat. Just run you fuel down to 1/4 tank and pour the alcohol in run it hard for a few miles and go get it tested
Lucient is offline   Reply With Quote
