Old 06-14-2005, 01:30 PM   #1
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
synthetic vs. the good stuff - oil & turbos
well, what are the pros and cons regarding different motor oil and turbos. synthetic compared to natural oil
im thinking about running synthetic oil from here on out on my kat project, and i was wondering if that would protect the turbo as well (t25)
is there any benifit in regards to coking oil in a turbo, better longevity that kinda stuff...
lay it on me
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline
Old 06-14-2005, 03:13 PM   #2
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
coking, if im not mistaken thats synomomous for bad dranage and pooling, which = bad.
synthetics, double edged sword, better lubricity(different from viscocity) however, synthetics will normally degrade at a lower temp then natural oils of same quality.
however, molecularly synthetic is better on metals. with higher lubricity from synthetic oil compared to natual oils at same viscosity lets u run thinner weight oil, hence better oil priming and flow/dranage
cheap synthetics < good naturals, cheap crap synthetics can cause leaks on seals
breakin in of turbos should be done with natural oil. break-in of turbo is super important, not just for longevity, most needle bearing chra's will spool up a tad earlier once breakin is complete. ball bearing chra's in my experience dont get that way, or maybe they just take that much longer to break in><
remember racing oil != street oil, they are 2 different animals.
ultraDorksGarage is offline
Old 06-14-2005, 03:19 PM   #3
2JZGTE
2JZGTE's Avatar
2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute
Send a message via AIM to 2JZGTE Send a message via MSN to 2JZGTE
I use synthetic in my supra, it works great for 500rwhp. Couple things I don't like about synthetic though:
1. It's expensive as s$#t
2. Likes to leak out of seals easier than regular oil (in my experience).
3. It's expensive as s#$%#$%#$%$#%.
Only reason I use it in supra is because of the power, synthetics have always ran better with the higher HP in her.
I usually run a synthetic blend or normal oil in my 240sx with sr20det. It has much lower power and and synthetic doesn't seem to have much of a difference on it.
Really you could go either way. Just get the right viscosity, I usually run 10w30, maybe a tad thicker. If your KA has high miles and not 100%, I'd probably just run blend or normal oil. GL
billy
R35 GT-R, R32 GT-R, Supra, S13, S14, FD3S
2JZGTE is offline
Old 06-14-2005, 04:30 PM   #4
Project D
Project D is an unknown quantity at this point
Send a message via AIM to Project D
I an synthetic in my DSM and loved it. I plan on running it in SR20DET when it arrives.
Project D is offline
Old 06-14-2005, 06:29 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
synthetic at a minimum, redline if you can.
Originally Posted by PHLIP
mrmephistopheles is offline
Old 06-14-2005, 06:47 PM   #6
bluemax
bluemax is an unknown quantity at this point
If you want to baby your car, do a search for BND oil. They will give you a personal blend for your beloved. BND had a small mention Grass Root Motorsports mag this month. Check them and give them a try
bluemax is offline
Old 06-14-2005, 06:50 PM   #7
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
I don't have a turbo yet, still building my spare motor. Bought my car with 156k miles and now it has 223k on it. Since I got it I've run nothing but Mobil 1 full synthetic. Haven't had any motor problems what-so-ever (knock on wood). I'll never run anything else (except for break-ins).
Bryan
upSLIDEdown is offline
Old 06-14-2005, 07:53 PM   #8
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
I Run Mobil-1 15w-50 usually. But When I can afford it, which has only been 2 times I like to run HKS Turbo Racing Oil 15w-50 but it is 80 bucks per change for that shit...you cant go wrong with Mobil-1. I Change every 5,000 klms...
late
Daryl
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline
Old 06-14-2005, 08:08 PM   #9
Phlip
Yes, I look like that
Phlip's Avatar
O'reilly sells the Mobile 1 oil in 4 quart bottles for $8.99 each, I got 4 of them today and 4 new filters from nissan, best price I have found to date, even better than Costco and Sam's club
Weirdo
And I write too!
Phlip is offline
Old 06-14-2005, 08:11 PM   #10
HaLo
from Canada, eh!
HaLo's Avatar
Get Motul synthetic oils. Really the best thing i could've done to my engine.
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
HaLo is offline
Old 06-14-2005, 08:20 PM   #11
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
AMSOIL, good stuff as well. But it's $$$
U13 and S13
zilvia members are friendly
ranisron is offline
Old 06-14-2005, 09:33 PM   #12
Blues13
Blues13 is an unknown quantity at this point
damnit...I dont think there's any O'reily's on the west coast.
Blues13 is offline
Old 06-16-2005, 07:16 AM   #13
90RS13
90RS13 is an unknown quantity at this point
Coking is actually when oil gets so hot the parts solidify and leave deposits of sludgy gross-ness. That's why people use turbo timers, so that the oil doesn't coke. Actually that is one of the main things that screws turbos.
90RS13 is offline
Old 06-16-2005, 08:23 AM   #14
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
Just use synthetic, dont understand why you wouldnt. you wont be able to feel any difference when u switch between syn and mineral but your engine will be happier.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline
Old 06-16-2005, 12:19 PM   #15
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
Royal Purple. bar none. only downside its dark already
hydropgrahics!
ls1......
420sx is offline
Old 06-16-2005, 03:56 PM   #16
ultraDorksGarage
i see ur point and what i meant in lame..ass terms was that coking is a byproduct of bad drainage, coking is not a big issue unless u have bad drainage, bad oil control ,or dont change oil. the biggest killer of turbos maybe changing oil, however the biggest problem for customizers is oil control, the placement of a turbo has direct correlation to drainage.
main use of turbo timers is not just for cool down, it is to allow oil to drain out of the turbo. coking is normally because oil has pooled in the hot centersection, then vaporizing to a certain degree leaving carbon deposits.
(people run timers for about a minute, check turbo temps at 15 secs vs 1min, its only slightly different, at least on my IRPyrometer)
what happens is u just boosted like its coo, hot dirty oil is in ur turbo, if u shut off immediatley that oil didnt have a chance to evacuate/flush(all turbos have some amount of pooling no matter what) this leaves deposits. cool down all though important, is easily attained within 10-15 secs after idle,(u arnet gonna get that cold while motor is still running), getting dirty oil out of centersection however inmho is most important part.
Old 06-16-2005, 09:22 PM   #17
upSLIDEdown
Ummm, if the motor is running, you oil isn't just gonna drain and be gone from the turbo. It's like he said, turbo timers allow the oil to cool down. If you're boosting your car, the oil is gonna get hotter than if the car is just idling. So you let it idle for a while (most people go far more than just 1 minute). The turbo spins at a very very high rpm (memory fails me of how high), and it also gets VERY hot. If you let the car cool down for a little bit, the oil cools down also and doesn't solidify in the turbo/lines.
Bryan
Old 06-18-2008, 05:45 PM   #18
MrFuel
MrFuel's Avatar
MrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to allMrFuel is a name known to all
Send a message via AIM to MrFuel
This is my first time with my 97 SR20det. I need to change the oil.
But i don't know, what oil filter i look for at the auto parts store? Can you guys help me out on this.
Also what spark plugs do i ask for?
MrFuel is offline
Old 06-18-2008, 06:40 PM   #19
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
royal purple or motul ftmfw. i won't run mobil b/c its no longer made from a synthetic base, and cuz i can't support that company from an ethical standpoint either.
brndck is offline
Old 06-18-2008, 06:47 PM   #20
S14DB
AFC #1
S14DB's Avatar
Wow, you picked a thread about oil from 2005 to ask these random if not common questions?
S14DB is offline
