Old 06-19-2008, 06:25 AM   #1
prodigys14
prodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choices
s14 window problem
searched and didnt find anything specific to this problem....my passger window would go down but if its not completely down it wouldnt go back up, its only when i roll it all the way down and play with the switch it would go back up, i wouldnt think its the motor since it still goes up quickly and it wouldnt be the amp since it goes up and down, im guessing its the regulator getting stuck or something? any help would be much appreciated
prodigys14 is offline   Reply With Quote
Old 06-19-2008, 07:25 AM   #2
TurboNetic05
TurboNetic05 is an unknown quantity at this point
my amp was bad and my windows would work occassionally. then just stopped completely. Replaced the amp and all is well now. Try the amp. They are pretty cheap. just ask someone who is parting out their car
TurboNetic05 is offline   Reply With Quote
Old 06-19-2008, 08:30 AM   #3
Fokai
Fokai's Avatar
Fokai is an unknown quantity at this point
Sounds like your motor and reg.
Fokai is offline   Reply With Quote
Old 06-19-2008, 08:33 AM   #4
TravisSW
TravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfection
Send a message via AIM to TravisSW
I kinda have the same issue with my driver side window.
Usually punching the door panel will get it going, but I don't think my amp is bad. I just resoldered the joints and it seems great, but when I pull the wiring in one direction, it works just fine.
Last thing I wanna do is rewire all that crap. >.<
1986 Porsche 944 Turbo (951)
1995 Nissan 240sx (S14) Miss ya.
TravisSW is offline   Reply With Quote
Old 06-19-2008, 10:18 AM   #5
projectRDM
projectRDM's Avatar
The amp only drives the driver side window, so that is NOT the problem if the passenger side window is acting up. Pull the panel, the regulator could be binding or jammed, or the motor is on it's last leg.
FORMERLY R240NA
Old 06-19-2008, 11:15 AM   #6
TurboNetic05
^^hmmm... i didnt know that the amp only powered the driver window. so how does the pass work?
Old 06-19-2008, 11:28 AM   #7
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
Pull the door panel, if nothing is mechanically binding then it is the switch itself on the Driver side. If the Driver side fails then the Passenger side will not work.
Sometimes all you have to do is take apart the switch and clean the contacts.
I too had the same problem and asked my friend who then took it apart and showed me.
slidingsky is offline   Reply With Quote
Old 06-19-2008, 12:04 PM   #8
prodigys14
pretty sure its the regulator cause the driver side works perfectly fine... do i have to replace it or can i just grease the tracks up?
Old 06-19-2008, 02:10 PM   #9
TurboNetic05
try greasing first before you buy anything
Old 06-19-2008, 04:10 PM   #10
projectRDM
projectRDM's Avatar
Incorrect. The amplifier is driven off a negative trigger from the main switch which relays to the motor, while the passenger side amplifier is internal within the main switch. If the amplifier goes out the main switch is still working, and therefore the passenger side window still works fine.
On 96+ models the amplifier is internal for both sides, and in that case if the main switch died, both windows would indeed not work. 89-94 and 1995 models with the external amp don't work that way.
FORMERLY R240NA
Old 06-19-2008, 06:44 PM   #11
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
it depends on what year your s14 is. always provide the year of your car because there are differences between the years.
look up window
http://forums.nicoclub.com/zerothread/253879
surreybc is offline   Reply With Quote
Old 06-19-2008, 07:11 PM   #12
slidingsky
slidingsky's Avatar
eh I have a 96
Old 06-19-2008, 07:18 PM   #13
surreybc
eh I have a 96
the 96 doesnt have an amp. its part of the switch.
Old 06-19-2008, 07:27 PM   #14
slidingsky
slidingsky's Avatar
I never said anything about an amp.
Old 06-19-2008, 07:35 PM   #15
surreybc
exactly. only the 95 s14 has an amp.
Old 06-21-2008, 03:59 AM   #16
prodigys14
mines is a 95, my best bet is the probably just greasing up the track of the regulator since its whats most likely the problem from what you guys said and cant be the motor since when it goes up its still quick
Old 06-25-2008, 04:06 PM   #17
DUFFM4N
DUFFM4N's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
im going through this problem right now, my driver side window would go down just fine everytime, but sometimes would have a problem going back up, i would just hold the switch "up" until it rolled up...and just yesterday the window got stuck going down 1/2 way...and wouldnt move at all
so my buddy said it MIGHT be the amp, went to the junkyard today, got an amp from a working window (tested it on other car) and my window still wont work....so im going back to the junkyard, and swap out the switch first (since its REALLY fast) and see if thats the problem....if not, then i guess its the motor =/
CLICK HERE FOR MY BLOG
Old 06-25-2008, 04:13 PM   #18
projectRDM
projectRDM's Avatar
The regulator could be binding up too.
FORMERLY R240NA
