Old 06-21-2008, 02:14 PM   #1
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
s14 Check Engine light on
Hi, I just got my car back from the mechanics and I noticed that my Check Engine light is on. They had to close soon so they weren't able to diagnose the problem. I'm going to need to drive my car today and tomorrow etc, and I would like to ask, how do I diagnose the check engine light? My car is 1995 240sx ka24de OBD I.
dued is offline   Reply With Quote
Old 06-21-2008, 02:50 PM   #2
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
You should be able to pull codes off the ECU's light. I don't remember the procedure off the top of my head but it's listed in the FSM.
If anything, start off with disconnecting the negative battery terminal first for a couple of minutes to reset the ECU. If that doesn't work refer to the FSM to see how you can check ECU codes.
Good Luck!
HalveBlue is offline   Reply With Quote
Old 06-21-2008, 02:54 PM   #3
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
my check engone light came on and i changed my 02 sensor it turned off and i get sick ass MPG too!
joshchewuhh is offline   Reply With Quote
Old 06-21-2008, 03:03 PM   #4
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
^ No. Now you just get normal MPG. Your car just sucked your gas like 10 cent hooker.
www.realize-jp.net
Old 06-21-2008, 03:49 PM   #5
dued
dued's Avatar
Thumbs up
Thanks for the replies. How do I get to the ECU on my car (s14)? Which panel do i take off, etc.?
Old 06-21-2008, 03:54 PM   #6
sc ka24e
sc ka24e's Avatar
sc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura about
passenger side kick panel/./ honestly just go to an auto zone and get them to lend u a scanner its free and plug it up to yur obd1 connector on my 95 its on the passenger side under and a lil to the left of the glove box... on 96 its under the steering wheel... i belive there is anotheron the driver kick panel but wutev...// pull that code and see whats up .. scanners are self explanitory just hook up turn only ignition on and select read code... u can also select freeze fram e and see when that code occures (engine rpm, coolant temp. etc) gl
sc ka24e is offline   Reply With Quote
Old 06-21-2008, 03:59 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Dude, get an FSM! C'mon you've been here for 3 years and you're asking questions as if you've never seen a 240SX before.
http://240sxtechdvds.org/FSMs.html
- Jimmy
Wanted:
TBD
For Sale:
TBD
