Old 06-23-2008, 05:52 AM   #1
prodigys14
prodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choices
airbag light flashing
before everyone starts flaming and giving me red squares i did a search on this and all that was found was either for aftermarket nonairbag or stock steering wheel... well i installed a s15 wheel on my s14 and the airbag light is flashing i pluged in the airbag and horn connectors too, what do i do to get rid of this problem? i got irratated of the flashing so i pulled the light out of the cluster for now but rather fix the problem for safety reasons, would the airbags still work if i got into a accident as of now? any help would be appreciated
prodigys14 is offline   Reply With Quote
Old 06-23-2008, 06:32 AM   #2
orion::S14
orion::S14's Avatar
You read and reset the airbag 'code' by using the door switch. Seriously.
Search on here for 'reset airbag light'.
- Brian
www.KA24DEvelopment.com
Old 06-23-2008, 11:56 AM   #3
prodigys14
yea i read about hitting that button by the striker 5 times? just wasnt sure if it works for other wheels besides stock
Old 06-23-2008, 11:58 AM   #4
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
did you try it before you asked??
Old 06-23-2008, 12:14 PM   #5
projectRDM
projectRDM's Avatar
Um, wow. The diagnostics is built in to the control unit, how would changing the wheel affect that?
And it's 7 times within 5 seconds of turning the key on.
FORMERLY R240NA
Old 06-23-2008, 06:24 PM   #6
prodigys14
ok thanks for all the info
