Old 06-26-2008, 03:00 PM   #1
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Manual Trans Speed Sensors S13 vs Z31 N/A
Ok guys need some help here, hopefully someone has a Z31 M/T speed sensor and could compare the bore diameter to that of the S13 M/T speed sensor.
Now your probably wondering what im trying to do, will I have a 97-01 Q45 VLSD with a 3.692 final drive which im going to install into my S13 but I want my speedo to be accurate or atleast close as possible, so after doing a little searching on Nissan FAST I was able to see that the Z31 NA M/T and S13 M/T both use the FS5W71C transmission's duh.
I also know that the Z31 comes with a 3.700 final drive which is close enough for me (3.692), so i wanan get my hands on a Z31 speed sensor from a 3.700 final drive equiped FS5W71C Z31 and see if the speed sensor fits which I think it should since there both the same trannys and I have no reason to believe the casting of the rear section shoudl be different.
Add some more pertinent info here for comparison sake:
Z31 FS5W71C
215/60/15
Overall diameter
25.15" (638.81mm)
07/83 - 08/87
3.700 Final Drive (18T VSS)
08/87 - END
3.900 Final Drive (19T VSS)
S13 FS5W71C
195/60/15
205/60/15*optional
Over diameter
24.21" (614.93mm)
24.68" (626.87mm)
07/90 - END (KA24DE)
4.08 Final Drive (20T VSS)
07/88 - 07/90 (KA24E)
4.08 Final Drive (20T VSS) F/Sport Package
4.08 Final Drive (21T VSS)
Old 06-26-2008, 03:02 PM   #2
projectRDM
projectRDM's Avatar
I'd bet it will fit fine, same rear case, it'd almost have to. As far as who has one, shit. I haven't seen a Z31 in a salvage yard in years.
FORMERLY R240NA
Old 06-26-2008, 03:17 PM   #3
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I hope so....
I'll throw up the tooth counts on the speedos in a lil bit, I wanna see how things stack up in favor with slightly smaller rolling diameter and what not.
Old 06-26-2008, 03:38 PM   #4
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Added VSS tooth counts to first post.
The Z31 also has a 17T VSS but its for a diff transmission so I dunno if it'll work so I didn;t bother posting that info.
Old 06-28-2008, 08:12 PM   #5
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Will I learned today the Z31 VSS does fit but its mechanical so I guess imma try Courtesy Nissan Texas to see if they have the NISMO 17t pinion available, its shows that it is for S13 but for S14 mostly all pinions are NLA.
Also the Z31 pinion is not removable, I tryed its totally different than that of the S13 pinion.
Pics:
http://www.courtesyparts.com/nms/s13/s13_4.html
Old 06-28-2008, 08:28 PM   #6
g6civcx
g6civcx's Avatar
How about an aftermarket speedometer? That's the only way I'm able to compensate for ring and pinion/wheel/etc. changes.
I use the GPS most of the time, and the mechanical speedo is only a backup.
I have an S13 auto VSS if you want to experiment.
Old 06-28-2008, 08:41 PM   #7
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
the same way that people re-solder the speedo for mph on a kph cluster, you should be able to compensate yours. just food for thought if it is that important
bigOdom1 is offline   Reply With Quote
Old 06-28-2008, 08:46 PM   #8
g6civcx
g6civcx's Avatar
He's dealing with the exact same problem I dealt with.
The calibration range of the factory speedo does not accomodate what he's trying to do. You can calculate and try to adjust for something as large as the mile/km conversion, but that's beyond the stock calibration. If you have info on this mod then feel free to post a link.
I was going along the route of an inline converter. The problem is that the Nissan VSS signal doesn't have an off-the-shelf converter and needs a custom unit.
I ended up going with GPS and a shaft sensor into aftermarket speedo as backup.
Old 06-28-2008, 08:48 PM   #9
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
What do you think about this?
http://yellr.com/yb_home.htm
Old 06-28-2008, 08:51 PM   #10
g6civcx
g6civcx's Avatar
Every vendor I contacted said that the Nissan VSS needs a custom application.
The closest I got was the manufacturer for SpeedoHealer. He's international but he's willing to make you one for free if you test it for him.
All of them has a range of adjustment, and depending on what you're doing, it may or may not be enough.
May want to let the vendor know so you have enough adjustment built in.
Old 06-28-2008, 08:57 PM   #11
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Hopefully nissanmotorsports has the 17t and 18t pinion in stock that would be so much easier.
Thanks g6civcx and everyone else how has replied.
Old 06-30-2008, 10:22 AM   #12
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Called Courtesy Nissan Texas and they said the S13 M/T speedo pinions are available at $25.00 each so I think imma end up buying both 17t and 18t pinions....
Old 06-30-2008, 10:00 PM   #13
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
he's talking about the writeup that had you add an extra resistor to the back of the cluster.
to change from Kph to MPH is out of the calibration range too. but with the added resistor it works fine.
I know, I did it to my old cluster.
PS.
here's the link
http://www.zeroyon.com/index/content/view/20/47/
Sir is offline   Reply With Quote
Old 07-01-2008, 05:47 AM   #14
g6civcx
g6civcx's Avatar
Originally Posted by Sir View Post
I saw that link before. Thanks for posting it. My comments below:
Originally Posted by knate
You can adjust the speedometer with the potentiometer, but you can't adjust it low enough to get to miles per hour because of that base resistance.
There are other resistors you could use, but just use something close to that value.
*Very important note* This does convert the odometer to miles, but will be slightly off.
These are the primary problems with it. I actually talked to Knate over at FA and his suggestion for me was to go with an inline converter because his fix it won't offer the adjustability for drastic/frequent gear changes.
Posted without permission: Looks like a good product, but I personally don't have much use for it I can do the km/h->mph for cheaper, but could be a good option for someone that needed frequent changes. Good find.
All he's doing is doing a 60% conversion. I suppose you can use a resistor and fine tune. The part about being cheaper is not true if you can get a prototype unit for free.
Good info though.
Old 07-01-2008, 03:00 PM   #15
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Ok I just ordered a S13 M/T 17t and 18t speedo pinion from courtesy for ~$60 shipped because I dont know which one is gonna be best suited for the 3.69 final drive so I bought both, hopefully this is accurate enough to avoid the other options which seem like alot of work....
Old 07-09-2008, 05:05 PM   #16
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Well I got the speedo pinions today, I haven;t installed the 3.69 VLSD yet but when I do i'll let you guys know the results.
Pics:
17t = black
18t = blue
Old 04-18-2009, 10:13 PM   #17
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Also liek to add to this thread that the 18t speedo pinion gear and the 3.69 FD are a perfect match as long as yoru running a comparable to stock rolling diamater tire size.
The speedo does require re-clocking so that it meshes with the speedo pinion drive gear in the transmission though.
If you look at the speedo its bolted down at the 6:00 O'clock, this needs to be reclocked to atleast 9:00 or 3:00 O'clock (which ever direction you want doesn;t matter) so that contact is made and everything works out like a charm.
Would have taken pics of how I did this mod but my battery died.
