Old 07-06-2008, 09:18 PM   #1
silviakid2790
silviakid2790 is an unknown quantity at this point
SR Spun Rod Bearing Question. PLEASE HELP!!
so im pretty sure i spun a rod bearing in my sr. it drive fine and sounds fine at idle but if you pop the hood and pull the throttle cable you can hear a horrible noise around 3k but then it stops if you let it go back down to idle. i know there are different grades of rod bearings, i read something about you have to get the numbers off the crank that will tell you which ones to get but i was wondering if all s13 sr's are the same? if so do any of you guys know which grade i need to get? please help me out, im trying to get this fixed asap. thanks!
silviakid2790 is offline   Reply With Quote
Old 07-06-2008, 09:21 PM   #2
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
ouch. where was the noise coming from? top or bottom
Old 07-06-2008, 09:34 PM   #3
silviakid2790
to be honest with you its pretty loud its hard to tell, but it sounds like its coming from the bottom
Old 07-06-2008, 09:50 PM   #4
motonagam
motonagam's Avatar
motonagam is an unknown quantity at this point
Have you checked the oil level? I've had that done to me where it'd make a really bad noise when I rev it up, but quiets down when I let it idle. The oil level appeared to be ok, but later found out it had the wrong dipstick... the dipstick was too long, so it read ok on the stick, but it was actually LOW, like it only had half a quart in it. Drained the oil, and refilled it to the correct amount, scribed a new mark on the stick, and it's been ok ever since.
motonagam is offline   Reply With Quote
Old 07-06-2008, 10:09 PM   #5
silviakid2790
i know it has the correct oil level, i changed my oil like 3 days before i noticed it real bad.... went and got my old oil filter, had a few gold flakes in it....
Old 07-06-2008, 10:10 PM   #6
Sileighty_85
Sileighty_85's Avatar
youp spun rod bearing
If it gets louder through the RPMS its a bearing
So first things first STOP RUNNING THE ENGINE!
the more you run it the more damage your causeing
pull the crank take it to a Machinest and he can tell you if the crank is still usuable
you maybe need to machine the crank if the crank is scared, so then you will have to get oversized bearings
the numbers are for the bearing sizes are for non fubar cranks so if the crank does not need to be Machined then you can use the formula to get new bearings the SR FSM has a step by step procedure on doing that
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-06-2008, 10:50 PM   #7
silviakid2790
yea i havent driven it since i really noticed it but idk how long it has been like that..... thank god i have a dd. looks like im gonna have to tear her apart soon
Old 07-06-2008, 11:17 PM   #8
sxe
sxe's Avatar
sxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond reputesxe has a reputation beyond repute
dont drive it!!! take your motor out, remove crank shaft, have them machine it, get bearings that fit the new machine sized crankshaft. whala, good as new, i had to do this idk how many times in my 96 gsx. dsm=crankwalk =/
sxe is offline   Reply With Quote
Old 07-06-2008, 11:20 PM   #9
silviakid2790
i know this is a newb question but ive never done anything to the bottom end of a car at all. after they machine it all down how will i know what size bearings to get? and would it be cheaper to get it machined or just buy a used crank that isnt scared up?
Old 07-06-2008, 11:26 PM   #10
sxe
sxe's Avatar
depends on where you go, and the machine shop will tell you how much they machined down, they usually have bearing for you. depends on how bad it spun. if the crankshaft is really egg shaped, you might be better off buying a used crankshaft, but ive always had better luck having the machine shop take care of it, spinning a rod bearing in my cases were all oil starvation, what oil do you run, and how often do you change it? were you at high RPM's when this happened? when did you notice this vicious knock?
Old 07-07-2008, 12:17 AM   #11
Sileighty_85
Wow is there an echo in here?
well it depends on when the bearing spun, If at idle and and ran for a few mins then the crank migh be fine, You can probably get away with just polishing it.
hopefully its not bent if you ran it for a while, and not too fucked up seeing that your not sure when it spun
But if they have to machine the crank they will tell you how much and maybe able to tell you the appropriate bearing size. If not you'll have to plasti gauge the clearances.
Get that shit balanced while your at it too.
It will be cheaper to machine it, if you buy a used crank what not to say that one would be bent or jacked up either.
More than likely you need a new oil pump too.
後輪駆動車1番
1986 SR86 - 200ish
Old 07-07-2008, 12:27 AM   #12
sxe
sxe's Avatar
nope no echo, this is a writin thread, there is no sound, therefor it is impossable to echo. i win 1-0.
Old 07-07-2008, 12:44 AM   #13
Sileighty_85
Lolz your funny Mr. Red Square Guy
P.S.
Its spelled Impossible
I win 10000000000-1
Game Over No need to thread jack this guys thread
後輪駆動車1番
1986 SR86 - 200ish
Old 07-07-2008, 07:52 AM   #14
projectRDM
projectRDM's Avatar
The crank will more than likely need machining, requiring oversized bearings. The machine shop will know what to do for you. Just know that if you spun a main bearing the block itself cannot be machined, you'll need a new one.
FORMERLY R240NA
Old 07-07-2008, 10:53 AM   #15
silviakid2790
i used royal purple, a shop that a lot of my buddies work at said that may be my problem haha, i try to change it every 3-4k miles but sometimes its a little longer (but nothing outrageous) and to be honest i dont know when it happend because the car drives fine and sounds fine at idle, i had just finished installing my koyo and fal fans and for some reason i wanted to pull the throttle cable and rev it up but then i noticed it and shut her down....havent driven it since
this sucks, im probably screwed
Old 07-07-2008, 04:55 PM   #16
silviakid2790
any other thoughts or suggestions?
