![]() Join Date: May 2006
Could this be a bad turbo?
HKS GT2530 on a S13 SR20 @ 17 psi
Symptoms: 1. Makes a grinding like sound from the turbo when I hit full throttle 2. Does not build boost but I didn't keep my foot on the gas for too long either 3. Blue smoke came from around the turbine and turbo elbow area, once that I noticed 4. After hitting full throttle for about a second and the rpms drop back down, the turbo would make a grinding noise for about a second 5. Rattling noise coming from the turbo during idle and normal driving Things I've already checked: 1. Turbo is not loose from the manifold or elbow 2. All hoses are secure and tighten 3. Shaft play about 1 to 2 mm 4. Turbo spins freely Anything else I should check? So do you guys think the turbo's done? I need to be sure before I go out and get a new one. |
![]() Join Date: Jun 2007
thats alot of shaft play man...
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
![]() Join Date: Nov 2006
that turbo is shot,
if there really is 1 to 2 mm of shaft play it is defiantly done past the point of a rebuild probably. shaft play should be in the .05 of a mm . |
![]() Join Date: Nov 2007
turbo needs rebuild. though, check to see if the turbine has hit the inside of the outlet
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
![]() Join Date: Dec 2006
Dont Bother Its toast, Rebuild it
check for oil down the exhauhst pipe, also see if any of the fins are cracked.. my sr stck turbo was shitted and those were some signs that i saw
#10 | |
This is like a 200 lb boulder falling on your arm and you look at your arm and see your bone sticking out and asking us if its broken.
Either way, just get it rebuilt. Slap on a t25 if you need to get around.
