Old 07-08-2008, 06:08 PM   #1
neverrain
neverrain's Avatar
neverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud of
Speedo only works sometimes. Replace it?
Hey all,
I have been "accepting" of a problem with my speedometer that doesn't really bug me, but I'm to the point where I want to correct it.
My speedometer only works about 50% of the time. Sometimes it works perfectly, sometimes it sits at zero, sometimes it just does whatever it wants and bounces all over the gauge.
Is this something that can be fixed or would it be easier just to replace the cluster? I plan to swap out my dash in the near future (cracked dash ftw) and if I need to simply replace it I would like to do it then.
Anyone else have this issue before?
neverrain is offline   Reply With Quote
Old 07-08-2008, 06:11 PM   #2
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
Originally Posted by neverrain View Post
Hey all,
i dunno about cluster, but u can change the gauge itself and its not that hard...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 07-08-2008, 06:11 PM   #3
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
sounds like u have a short or a bad ground...pull the cluster and check the sub harness between the back of the cluster and the dash harness (it unplugs in 2 spots under the dash behind the cluster)
the dash wires get old and very brittle and CAN crack and cause cluster problems
or the speedo itself could just be going bad...but theyre cheap enough to find around (like 20-30 bux for the unit...if that)
Old 07-08-2008, 06:36 PM   #4
neverrain
neverrain's Avatar
Yea i was actually wondering if it was wire related or not, but ive been lazy approaching it. Just figured I should probably look into it when I pull my dash. Thanks for the info.
Old 07-08-2008, 08:15 PM   #5
kevinphan
kevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud of
If you want I have a mint cluster for sale.
kevinphan is offline   Reply With Quote
Old 07-08-2008, 08:23 PM   #6
neverrain
neverrain's Avatar
How much? shipped to 91402?
Also, another thing I didn't think about at the time was that my odometer and trip odometer don't always work (which isn't a bad thing). Although this likely doesn't change what the problems could be.
Old 07-08-2008, 09:15 PM   #7
kevinphan
44$ shipped?
Ready to ship whenever.
Old 07-08-2008, 09:17 PM   #8
krazydriver
krazydriver is making a name for him/her selfkrazydriver is making a name for him/her self
Definitely a grounding issue if it's affecting the whole cluster like that. You really just need to check it. It'll be a simple fix.
krazydriver is offline   Reply With Quote
Old 07-08-2008, 10:44 PM   #9
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
kevinphan has a sohc gauge cluster.
What engine do you have?
reccakun08 is offline   Reply With Quote
Old 07-09-2008, 02:00 PM   #10
kevinphan
Yeah that cluster came from a SOHC
Old 07-09-2008, 02:23 PM   #11
Jordn
Jordn's Avatar
Jordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfectionJordn is close to perfection
Is it *just* the speedo? Or rev counter too?
Check the speed sensor on the gearbox. If its not reading right your speedo won't work and neither will your odo.
Check the wires coming off the sensor to make sure they are't fubared. Pull the sensor out of the box and check it visually too. Some of the teeth can snap as the cog is plastic and give hit and miss readings.
Jordn is offline   Reply With Quote
Old 07-10-2008, 07:44 PM   #12
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
^^ Speaking of that, when I bought my hatch the speedo would be intermittent like that. Well I decided to pull the speed sensor out before I sodl the tranny a few weeks ago, and the clip that help the gear onto the sensor fell off due to being bent.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
