Old 07-20-2008, 10:14 PM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
need some help
my SR has swap from my old s13 which is a '92 to a '89 s13.
wiring harness has been rewired for the the 89 s13.
SR will start if i hook up a wire from the starter to the positve terminal on the battery. but when i turn the key it wont start.
why is it not starting a turn with the key.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 07-21-2008, 12:32 AM   #2
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
check to see if you are getting voltage to the starter when you turn the key. is the starter even clicking when you turn the ignition. you're bypassing the iginition circuit when you connect the starter directly to the battery. check your wiring, relays and fuses.
makulit054 is offline   Reply With Quote
Old 07-21-2008, 12:38 AM   #3
hassanbakar123
hassanbakar123 is an unknown quantity at this point
something similar happened to me ended up being the ignition relay? i think thats what its called, the blue relay on passenger side fender next to the battery
bypass it and see if it will start
hassanbakar123 is offline   Reply With Quote
Old 07-21-2008, 12:47 AM   #4
makulit054
makulit054's Avatar
there's two blue relays in that fuse box. swap them. if it doesn't work then it's either you have two bad relays or something else is not working.
Old 07-21-2008, 08:07 AM   #5
s13silvia123
all the fuses are good.
al the grounds are good and connected.
when i turn on the key to the on postion it wont start the car.
bypassing the positive on the starter to the battery it works.
i'm getting fuel pressure.
Old 07-21-2008, 05:42 PM   #6
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Did you connect the black/yellow wire from the harness onto the starter? That's the positive ignition signal to the starter... Most of the time that wire comes loose so you'll need to secure it onto the starter better.
Old 07-21-2008, 09:41 PM   #7
s13silvia123
it was done correctly and it was not loose or anything.
Old 07-22-2008, 09:24 AM   #8
DriftCat
DriftCat's Avatar
DriftCat is making a name for him/her selfDriftCat is making a name for him/her selfDriftCat is making a name for him/her self
try your inhibitor switch. its a little toggle thats depressed when you push in the clutch. I had that happen and its a really quick fix. Theres a flange off the pedal with a pad that pushes it and my pad fell off so I taped a Monster tab to the flange and it depresses it fully now.
DriftCat is offline   Reply With Quote
