Old 03-24-2003, 05:15 PM   #1
Zemus
Zemus's Avatar
Zemus is an unknown quantity at this point
Send a message via AIM to Zemus
j30 brakes
I went to the junk yard today, and found a j30, i was consitering taking the brakes from it. But first i have a few questions:
#1 Will they fit
#2 Do they suck? Do are they good? Or are they just as good as mine.
#3 If i was to do a 5 lug conversion, woud that work?
Zemus is offline   Reply With Quote
Old 03-24-2003, 05:35 PM   #2
NiteKids
NiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymore
Send a message via AIM to NiteKids
1. Beats me
2. if they have more then one piston most likey they are better!
3. if they have a 114.3 bolt patern maybe and also if they fit the 240 caliper braket bolts
NiteKids is offline   Reply With Quote
Old 03-24-2003, 05:37 PM   #3
AKADriver
AKADriver's Avatar
Yes, they'll fit in the front. You'll need a 5 lug conversion to use the rears because they have the drum parking brake like a 300ZX. The fronts you can just redrill.
Do they suck? Nah... IIRC they're the same as Q45 brakes in the front (280x28mm rotor, 2-piston caliper) and probably in the back too.
Old 03-24-2003, 05:54 PM   #4
240racer
240racer's Avatar
240racer is an unknown quantity at this point
Hey did you check if that had the LSD in it, if it does, can you let me know where the junk yard that you found it in is? email me at [email protected] or post here.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 03-24-2003, 06:46 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
I'm in the middle of adapting the Q45 rear e-brake assembly to my 4 lug setup. It looks like a simple spacer will suffice to fill in the gap where the 5 lug hub originally was. I might just take the 5 lug hub and cut off the section that's sandwiched between the e-brake bolt and the backing plate.
AceInHole is offline   Reply With Quote
Old 03-24-2003, 09:50 PM   #6
Zemus
Zemus's Avatar
wow thanks for all the help, and 240racer, just dont steal the brakes from me, i really wanted the VLSD also to sell, but if you want it its yours, ill email the junk yard its in, and im not sure if it has LSD, but it might.
