Old 03-28-2003, 10:05 PM   #1
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
100,000 mile rods
think rods with that many miles can handle up to 10psi of boost...(not constantly 4 normaly) so wut do u think??
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 03-28-2003, 10:55 PM   #2
240racer
240racer's Avatar
240racer is an unknown quantity at this point
Mine have 150,000 and I'm shooting for 15psi. If you don't plan on revving higher then 7200, stock redline, then you should be fine, that's what puts the most stress on the rods. They are pretty solid rods from the factory, forged and shot peened.
Dennis from unstable-hybrids has been running 350hp on his stock internals, so that means rods. The pistons are just fragile and not resistant to detonation. The rods don't take the brunt of that problem. It can weaken them though. Most often a rod breaks in tension, not buckling (compression) so that isn't because of making power, it's because the piston is heavy and it's trying to pull it down really fast. The speed that it pulls it down is dependant on rpm. They also often break due to spun bearings or lack of oil and other bearing related problems.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 03-29-2003, 01:35 AM   #3
syco3d
syco3d's Avatar
syco3d is an unknown quantity at this point
Send a message via AIM to syco3d Send a message via Yahoo to syco3d
240 Racer: If you happen to know off the top of your head, what kind of turbo set-up is Dennis from unstable-hybrids running?
It's just that I'm looking at going KA-T fairly soon, and 350hp has been my goal. So as I start gathering info on parts and prices, it's nice to know what other people have done to achieve that power...
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
What does that spell?
CRAP!
syco3d is offline   Reply With Quote
Old 03-29-2003, 02:34 PM   #4
240racer
240racer's Avatar
Originally posted by James
Regardless of miles- do a compression check and see if it checks out. That is the deciding factor.
I don't think he is planning on using the stock pistons, he just wants to reuse the rods. That's what I did, I have arias pistons and I am using stock rods as well.
Dennis is running a JWT ecu with a stock motor and probably a kinda custom turbo setup. I think he has cobra maf and 50lb injectors. do a search for the cobra maf and 550cc injector thread and you will find about 3 pages of goodies.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
Old 03-29-2003, 02:40 PM   #5
Muzzy
Muzzy's Avatar
yea i was just gonna go with some ross pistons and keep my stock rods if i could
lemme have a dollar
Old 03-29-2003, 08:06 PM   #6
syco3d
syco3d's Avatar
Originally posted by 240racer
[Bdo a search for the cobra maf and 550cc injector thread and you will find about 3 pages of goodies. [/B]
Thanks alot man...I've always known to use the almighty search button, just a question on what to search for.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
CRAP!
Old 03-31-2003, 12:23 PM   #7
d240t2
d240t2 is an unknown quantity at this point
Send a message via AIM to d240t2
Some info on my car is on the website, www.unstable-hybrids.com under projects. Stock engine, cams, JWT ECU, 50lb injectors, etc.
Dennis
d240t2 is offline   Reply With Quote
