![]() Join Date: Dec 2002
She Runs!!(ka-t)
well, the car is running!
just have to do some minor tuning and program the secondary injectors. 7 p.s.i. right now 10 - 12 p.s.i. when done got some pics
www.soundworksinc.net kkk k27 hks b.o.v. jgs front mount split-second a.i.c. vortech s.f.m.u. walbro 255 lph |
![]() Join Date: Apr 2002
Congrats bro. The fun has just started!
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter. |
that kkk k27 spools up super fast!
cant wait to run it at 10-12 p.s.i. with it fully tuned.
![]() Join Date: Jul 2002
Are your going to run 10-12 psi on stock injectors? Do you plan to build the engine at all. Im piecing together a kit and want to get as many examples of KA-Ts as possible. Luckly there are alot on this board.
'98 240SX -s13 -> s14 Injen intake swap -B&M Short Shifter |
im gonna run 1- - 12 p.s.i.
with the 2 extra injectors in conjunction with my stock injectors. i dont wanna change normal driveability thats why i still have stock injectors the 2 extra ones will fill in where needed(440 each)
#9 | |
Autox Technician
![]() Join Date: Dec 2001
![]() He has a stock ECU from what I know, with an extra injector controller (forgot which one) to control the additional injectors. His setup has one injector before the turbo to cool the intake charge a bit, and another injector before the TB to add fuel under boost. He's also got a Walbro fuel pump and a Vortech Super FMU. All in all, he's got a lot to work with, and all of his adjustments will only affect the boost side, leaving everything during non-boost compltetely fueled by stock components. Not a bad idea, but getting it to run perfectly will take some time and dyno tuning with a WB O2 (unless I ever get off my ass and make my own WB O2 and let him borrow it for a few runs ![]() Anyways: So did changine the setup help your idle?? Looks like you've redone the AICV and breather lines. I'm really wondering if the AICV line should be on the boost side though. You might be leaking boost and not know it ![]() How's the BOV?? Are you getting rich between shifts?? It's looking good... I think it looked better with the red hoses up front. It matched your plugs and stuff. The wire loom looks cheesier than the red. Even so, as long as it works right?? I'll stop by the store on saturday maybe and check it out. Take a better side by side shot cause I just put my rims back on ![]() ![]() As a last note: that air filter I bought is junk. Ended up having to buy a paper element filter, cause the foam sucks into itself and chokes the car BAD. I'll pop it on and show you when I get back to the New Haven area.
stock ecu
split-second makes an extra injector controller its windows based and has real-time programing the module is boost dependant and increases the fuel flow out of the 2 extra injectors as the boost p.s.i. goes up. thats what im using to compensate for the extra fuel needed
ace,
bring that filter back and ill give you your $$$ back sorry man!(first time with that brand) i have an injen filter ill give you instead i put the loom there for now im actually gonna run all stainless braided hoses for everything micah came by today, and i took him for a ride your set-up is lookin hella better!! the black piping goes well
#13 | |
Autox Technician
thanks for the compliments on my setup. i spent some time and fabbed some sheilds for all the firewall lines. just got a fre more things to tie down and it should be set untill i get the new turbo ![]() what'd micah say about your car?? I've taken him for rides at 4psi, but never really got on it when he was in the car. I wonder what his impression was having been in 2 different KAt cars. can't wait to put the cars side by side again!!
#14 |
![]() Join Date: Jul 2001
Wow, very interesting. Sounds like a clean / thurough setup. Now that you have 1-12 psi, did it give you car that extr pull (turbo pull) that gets the heart pumping? hehe
#15 |
dont worry bout the box.
i"ll send that **** right back!! i just wanna make sure you get the right stuff. micah was just smiling for the ride i didnt really get on it cause i still havent tuned those extra injectors i replaced my old hks b.o.v. with the s.s.b.o.v. that thing is loud as hell!! you gotta come by and go for a ride. between the b.o.v. and the open wastegate it sounds pretty cool!!!
#16 |
sorry, i meant 10 - 12 p.s.i.(typo)
#17 | |
Autox Technician
#18 |
"SOUNDWORKS" there is actually a stereoworks nearby(my old partners) oh the horror!dont get confused! they're not into the import scene.
put your car at 7 p.s.i. and we'll show Thon the power of the KA!! USDM style!!! (In my book,torque is king!!)
#19 |
CT is home of the KA-T
i think per capita we have the most ka-t's around! lol,lol
#20 |
![]() Join Date: Nov 2001
yeah I was wondering about the breather hose too. When I had that on the boost side, it gave me problems. I had lots of smoke and I think it caused my valve cover gasket to go out. Now I just run it out the bottom of my car because I'm lazy and don't care. Maybe when I go to the track I'll throw it into a catch can. I don't have enough room to run it before the turbo and I didn't really want that crap going through the turbo anyway.
Adam '89 coupe KA24DE+T 14.1 @ 104 MPH '88 Celica All-Trac turbo stock, but no more ecu codes!! |
#21 | |
Autox Technician
#22 |
the car idles fine now.
no stuttering or fluctuation. it goes down some when im coming off the throttle to a stop, but quickly recovers i dont have any of those open b.o.v. problems either.
#24 | |
![]() Join Date: Jan 2002
ya ill be done soon, ill take you a ride in my car at 30psi. you'll never want to grive your car again ![]()
240SXONE www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx ![]() ![]() |
#26 | |
