Old 03-31-2003, 12:31 PM   #1
projectsilvia1
projectsilvia1's Avatar
projectsilvia1 is an unknown quantity at this point
turbo to manifold HELP
i am having a problem getting to the bolts on the flange from the manifold to the turbo....i can get to the first two on the outside but the other two i can not reach. the question is do i have to take the manifold off to get to the other bolts?...please help or i wont be able to go to the drift show off this weekend.
Mike
AIM: projectsilvia11
89 240sx 13.22@91mph
Got Spool??
AIM: S13 RKT
projectsilvia1 is offline   Reply With Quote
Old 03-31-2003, 12:44 PM   #2
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Best thing to do is take the whole thing out at once. Manifold and turbo + turbo extension. than you have access to all bolts. Be sure to refill block with coolant as those hardlines are a pain to put back in the block.
now if you had a lift you could try and get at those back bolts, but I found that this is the easiest way when working with jackstands.
G'luck!
Jed
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 03-31-2003, 02:30 PM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
I second that. Just take everything out. Replace all the gaskets while you're in there. If you need new ones, get them from Wayne at Phase2 (he can probably overnight them to you). Get a new mani gasket (it WILL rip) and get a new gasket that goes between the mani and the turbo.
Then get all new stainless fasteners and lock washers so that sh*t doesn't come loose again.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 03-31-2003, 05:25 PM   #4
projectsilvia1
damn that is a **** load of work just to get the mother f'er off
i think i am going to take my time and get the stuff as i can cause i don't have the time to do all this stuff.
mike
Got Spool??
AIM: S13 RKT
Old 03-31-2003, 07:19 PM   #5
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
You can get to the mani bolts without taking the turbo off? I can't get to them. I havn't tried that hard either though. This is on my SR. The motor is out of the car, so other stuff isn't in the way. just the turbo and Mani are on the exhaust side. Thanks in advance.
RBS14 is offline   Reply With Quote
Old 03-31-2003, 08:40 PM   #6
uiuc240
uiuc240's Avatar
Yes. Just use a wobble for the tough ones. You can get all of them out with the turbo attached. I have done it personally.
Eric
2002 Mazda Protege5
