Old 08-05-2008, 03:55 PM   #1
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Tripple pressure switch and E-fans!
Hey in a bit of a bundle here. I removed the A/C, bled teh coolant. However my E-fans wont come on, unless I manually trigger them/
Does the triple pressure switch need to be plugged in for the A/C harness to kick the fans on @ 203f?
thanks!
Bigsyke is offline   Reply With Quote
Old 08-06-2008, 10:46 AM   #2
Bigsyke
Bigsyke's Avatar
anyone? Iin the FSM manual it looks like the fans neg wires are connected to the triple pressure switch.
Old 08-06-2008, 01:30 PM   #3
projectRDM
projectRDM's Avatar
Yes. A dead switch or loose will cause that.
FORMERLY R240NA
Old 08-12-2008, 11:20 AM   #4
Bigsyke
Bigsyke's Avatar
Update: The fans still kick in @ 203*f without the triple pressure switch. So it can be removed.
and ericcastro you have no reason to neg rep me in this thread.
Old 08-12-2008, 02:44 PM   #5
projectRDM
projectRDM's Avatar
Strange. I'll have to double check that myself.
FORMERLY R240NA
Old 08-12-2008, 02:55 PM   #6
Bigsyke
Bigsyke's Avatar
The FSM chart routed both Ground wires on the s14's A/C fan harness back to the triple pressure sensor.
My theory is the Triple pressure sensor is not a switch for the fan, but doubles as a relay and the ground wires still route back to the ECM.
I drove around for a while, unplugged the triple pressure switch from the harness, and sure enough the fans kicked in on low (203*f)
I just need to make sure its @ 203*F and not 212*f.
I can still press the A/C switch on the climate controls and the E-fans will kick in. The FSM states a few things control the Fans, triplepressure switch, ECT, VSS, and I forgot the other.
