Old 04-03-2003, 05:19 PM   #1
ThE_BoMB
ThE_BoMB is an unknown quantity at this point
Send a message via ICQ to ThE_BoMB
Unhappy starting noise
Well I got a used 1991 240sx the other day and I noticed a noise now when I started it up after having a bit of fun in my new car, first it starts goes to 1500 ish rpm then goes way down round 150 then a screech and it back up to 900, I thought it might be a belt but does anyone have any suggestions?
ThE_BoMB is offline   Reply With Quote
Old 04-03-2003, 09:31 PM   #2
Apparition
Apparition's Avatar
Apparition is an unknown quantity at this point
Send a message via Yahoo to Apparition
If its a high pitch squeal and eventually disappears its the pulleys. I had this replaced and it fixed that problem.
1990 240sx coupe *sold*
Apparition is offline   Reply With Quote
Old 04-04-2003, 01:13 AM   #3
thx247
thx247 is an unknown quantity at this point
you can check the belt deflection by just pressing on the belts and seeing if any are lose. Also check bolts holding tensioners in place and see if any are lose, I had a bolt rubbing against the power steering pully once. Sucked.
thx247 is offline   Reply With Quote
