Old 08-19-2008, 04:20 PM   #1
pinky121388
pinky121388's Avatar
pinky121388 is making a name for him/her selfpinky121388 is making a name for him/her self
can someone please help me with a tranny problem?
Hopefully this enough details to explain my problems.
I bought an exhaust system, and a shop instaled it, becuase i needed some other parts. the shop welded the exhaust to the what looked like a exhaust hanger #1 closest to tranny/driveshaft/tranny mount..all in this area....
I did a 5spd swap and had to saw the exhaust off of this hanger so i can remove the tranny mount to take down the tranny. when i sawed it off i never replaced this piece i sawed off. Now my transmission shakes at low speeds.
this piece looked like a rubber block at the end of transmission where the driveshaft connected. This piece also bolted up to the back of the tranny mount, and hung off of it..
if you know what it is please let me know.. if u have it sell it to me please.. or tell me where i can get it.
pinky121388 is offline   Reply With Quote
Old 08-19-2008, 05:18 PM   #2
aznpoopy
aznpoopy's Avatar
#1. its an exhaust support/insulator
part# for s14 is 20535-s14001
part# for s13 is 20610-s13001
there are brackets that go along with it that have separate part numbers
#2. you get one the same place you get any oem part - a nissan dealership. go to courtesyparts.com and you can find your own parts / part numbers in the future. they have an online catalogue of parts, diagrams/pics included.
#3. it supports the exhaust. it does not support the transmission, nor would not having one cause your transmission to shake. you are either hearing the exhaust moving around or your transmission is not properly secured to the mounts/car. not having one is no problem. i've never had one on my car.
Old 08-19-2008, 05:54 PM   #3
pinky121388
then what would cause the problems.. i had factory mounts and it shook, i replaced with nismo mounts and still shook.. cross member is bolted down by impact, nismo mount is bolted down as well.
when i installed the tranny we lifted the car to bleed all lines, and noticed the tranny was moving around.. couldnt figure out why???
when im at a red light i and slowly take off it shakes up and down like a mount wasnt there. All i know is this problem bugs me and i wish to get it fixed very soon.
Old 08-19-2008, 06:26 PM   #4
aznpoopy
aznpoopy's Avatar
i would guess engine mounts are crapped out or the secondary bolts that secure the transmission to the tranny mount aren't in
Old 08-19-2008, 06:30 PM   #5
Sileighty_85
Sileighty_85's Avatar
Sounds like your Trannys not bolted to the engine Lolz
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-19-2008, 09:08 PM   #6
pinky121388
new motor mounts too, it stills shakes from old ones to new one..
Old 08-19-2008, 09:08 PM   #7
pinky121388
well if it wasnt bolted up, then how can i drive everywhere... my car drives fine...
Old 08-19-2008, 10:40 PM   #8
Mikey88
Mikey88's Avatar
Mikey88 is on a distinguished road
trannies are the worst thats why you never get a prostitute you'll never no what you get till the last minute... jp man hope you get the problem fixed
Mikey88 is offline   Reply With Quote
Old 08-19-2008, 10:54 PM   #9
pinky121388
yea seriously. i called my local dealership, and they said for me to come in and they can check it for 98 bucks, just to see whats wrong with it.. but i rather search around to find the problem before i blow 100 bucks on that..
Old 08-19-2008, 10:59 PM   #10
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
i get this same type of vibration at mid rpm's and deceleration. its terrible. brought it to an exhaust shop and they couldnt figure it out.. might be my tranny. but i have nismo motor mounts and transmission mount. no clue but it drives me nuts. i know how you feel...
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline   Reply With Quote
Old 08-19-2008, 11:02 PM   #11
pinky121388
please tell me where u got these part numbers, i searched courtesynissan for them, there was no matches.
Old 08-20-2008, 07:29 AM   #12
aznpoopy
aznpoopy's Avatar
courtesynissan is the wrong website.
go to courtesyparts.com.
then click on the big red link that says "click for our new ONLINE CATALOGUE." the normal search on the main webpage is not the same as the catalogue search.
then you can enter the parts # after selecting your car on the top right search field in the grey bar on top, or you can go into the genuine parts catalogue and find it manually, which is what i did for you in the first place.
Old 08-20-2008, 07:39 AM   #13
xplicit240
xplicit240's Avatar
xplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nice
Send a message via AIM to xplicit240
this happened to me as well. make sure your drive shaft is secure and mounted on correctly. then voila~ problem solved.
xplicit240 is offline   Reply With Quote
Old 08-20-2008, 07:45 AM   #14
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
loose driveshaft would definitely cause some heavy vibration. all that vibration could actually snap the driveshaft bolts. make sure everything is torqued down to specs.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 08-20-2008, 12:34 PM   #15
ericcastro
ericcastro's Avatar
Im having the same problem.
I redid my clutch at the track the other month, and since then its been happening.
When I had the tranny out, there was a rubber bushing type of deal that sits on the rear end of the tranny, on the top site. this thing was completly crapped out on mine, so i just let it break apart and fall all over.
No I got these vibration issues under load and when decelerating using downshifting.
I believe this might be your problem. get under there and look.
Old 08-20-2008, 08:04 PM   #16
pinky121388
does it look like a rubber block.. i no mine is off...
my tranny doesn't vibrate.. it shakes up and down like.. and makes a clicky noise.
Old 08-20-2008, 09:28 PM   #17
ericcastro
ericcastro's Avatar
I think its a rectangle shaped rubber block that goes on the top of the tranny, between the tranny and the floor.
Old 08-23-2008, 12:50 AM   #18
pinky121388
yea and it also acts a exhaust hanger!!! i missing that, since then tranny been bouncin like a basketball.. at low speeds. annoying as hell... i cant seem to find one.
Old 08-23-2008, 12:55 AM   #19
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
you sure it not exh hittin trans?
the piece you cut?
can you man handled tranny and move it? by hand? try new mounts..
I got a spl one? it makes thing tighter... when My wheel hops my stick shift goes balannas...
gl tho
sillyvia13 is offline   Reply With Quote
Old 08-23-2008, 12:59 AM   #20
pinky121388
when i come to a stop, my tranny bounces like a ball up and down.. i replaced mounts, check every bolt every thing 3 times, and had my friend check.. on our lift.. we cant find it... the only thing that leads me to solve this problem is the rubber dampener that connects the exhaust to tranny mount.
Old 08-23-2008, 01:04 AM   #21
DreamN
DreamN's Avatar
Trader Rating: (54)
^ do you see anything similar to what you're describing?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 08-23-2008, 01:18 AM   #22
Sileighty_85
Dude if your talking about Item #20621 & 20651
They have nothing to do with your tranny bouncing , Its for stablizing the exhaust, not the tranny. If your tanny being bolted to the chassis does not keep your tansmission form boucing why would your exhaust with a rubber bushing hold it down?
Its not need, mine broke it half and I've never had an issue like your talking about
Video and pics would help
後輪駆動車1番
1986 SR86 - 200ish
Old 08-23-2008, 01:24 AM   #23
DreamN
DreamN's Avatar
Trader Rating: (54)
^ I still think you have loose driveshaft bolts.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 08-23-2008, 04:29 AM   #24
ericcastro
ericcastro's Avatar
Maybe the carrier bearing bushing is going?
Old 08-23-2008, 10:49 PM   #25
pinky121388
no cant be that.. i installed the tranny and drove car the same day... it bounced.
i can double check the driveshaft bolts but i dont think it is the problem...
Old 08-24-2008, 05:36 PM   #26
burnsauto
burnsauto's Avatar
•jack up the car and put it on jackstands
•take the driveshaft out
•get in car
•start car
•put car in gear
•engage clutch and give it some gas (not a whole lot)
worse thing that'll happen is you'll lose a little fluid, but manual trans fluid isnt for lubrication really, more just to help with temperatures in the transmission.
If the transmission still shakes, then somethings not aligned correctly, or your main transmission bearing may be on its way out. If it stops shaking, then its somewhere further down the drivetrain, and not the transmission/mounts.
Old 08-24-2008, 05:42 PM   #27
DriftMUH
DriftMUH's Avatar
DriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of lightDriftMUH is a glorious beacon of light
that exhaust insulator broke the day before i had to sell my car.. pita i swear
"Im invisible and impossible to touch" ~Mr. Lif
DriftMUH is offline   Reply With Quote
Old 08-27-2008, 02:27 PM   #28
pinky121388
•get in car
•start car
•put car in gear
ok well im putting in my coilovers on friday so i will check it out then, when i get to shop..
Old 08-27-2008, 07:57 PM   #29
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
ive had 3 s-chassis cars and that thing is one of the first parts to come off of all of them. pretty much useless, especially if youre running anything other than oem exhaust
aNskY is offline   Reply With Quote
Old 08-27-2008, 08:28 PM   #30
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
what about the pilot bushing in the flywheel?? when u did the swap did u replace that???
or
i get the same thing when i take off from a light. its the bolts that go through the rubber damper, only one comes loose time to time.shakes like a crack head. id check those out too
unionautoclub.com
dori_sil8t is offline   Reply With Quote
