Old 08-22-2008, 08:43 PM   #1
gripDRIFTschassis
gripDRIFTschassis is an unknown quantity at this point
AFC not getting TACH SIGNAL
I know a few are gonna flame for me using an AFC......
I installed the AFC NEO and everything is working fine its just that its not getting a tach signal and i dont want to tune it with it only going by the TPS.. just need some advice..
***Have a SOHC Cluster in the car..also wanted to know if me not having the DOHC Cluster effects the AFC also not to read RPM'S***
THANKS..
gripDRIFTschassis is offline   Reply With Quote
Old 08-23-2008, 08:56 AM   #2
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
check the wire connection on the tach signal wire and triple check to make sure both wires are the correct color
good luck
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 08-23-2008, 09:40 AM   #3
Massimo Power
Massimo Power's Avatar
Massimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to all
Send a message via AIM to Massimo Power
its definetly the wire that reads from the ecu.. you need to check that...
www.massimopower.com
PH: 1(951)402-5386
EM:[email protected]
Special Thanks To:
www.aeperformance.com
www.domospeed.com/blog
For Their Continued Support
Massimo Power is offline   Reply With Quote
Old 08-25-2008, 11:00 AM   #4
gripDRIFTschassis
kinda stupid but i caught it....
cluster just needed to be changed to the DOHC....
THANKS
550cc, afc, neo, tach, z32
