Old 08-22-2008, 06:06 PM   #1
KwKouki
KwKouki's Avatar
KwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfection
Send a message via AIM to KwKouki
wastegate actuator rod is rattling
I dont know what its hitting, but not under load its constant at 2k *which is irrelevant*
we took a wrench extension and put even so slight leverage when the engine is at 2k and it stopped it completely. I do not know what the rod is vibrating on. anyone else have this problem
t28 specR turbo if that helps
KwKouki is offline   Reply With Quote
Old 08-22-2008, 06:09 PM   #2
S14DB
AFC #1
S14DB's Avatar
Preload it.
Old 08-22-2008, 06:17 PM   #3
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Sounds like it might be open and causing a vacume leak which would explain the 2000rpm idle ????
WoolyS14DET is offline   Reply With Quote
Old 08-22-2008, 06:20 PM   #4
KwKouki
KwKouki's Avatar
nononono, what I meant was it only rattles at 2k RPM. car idles rock solid around 1k. under load it will rattle around 2-3.5k
Old 08-22-2008, 06:23 PM   #5
WoolyS14DET
Trader Rating: (18)
Sounds like the rod is loos and vibrating against the shell of the waste gate ???
Old 08-27-2008, 02:41 AM   #6
KwKouki
KwKouki's Avatar
thats pretty much the noise, its driving me crazy, you can hear it from down the street
Old 08-27-2008, 02:48 AM   #7
shifts13
shifts13's Avatar
shifts13 is on a distinguished road
yup happened to my hks actuator. i set it too loose so do what s14DB said.
shifts13 is offline   Reply With Quote
Old 08-27-2008, 03:03 AM   #8
KwKouki
KwKouki's Avatar
im gonna go ahead and turn it a couple times to see if that stops the rattling, if that cures my problems its ponykegs and hookers for all
