Old 08-27-2008, 08:33 PM   #1
SinisterSntra91
SinisterSntra91's Avatar
SinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfection
S14 ABS spindle knuckles vs. Non ABS spindle knuckles is there a difference?
As the title states.... is there a difference? I know the main difference is in the hub bearing assembly where the sensor rotor rings are, but where does the ABS sensor go? According to Courtesy Nissan there is no alternative part # listed:
So is there a difference or are they really in fact all the same? Where does the abs sensor go/bolt to? Reason I ask is unfortunately for my 350z cluster to work I have to install ABS on my non ABS S14.
Now metal fabricating, welding and powder coating. PM me with your needs!
SinisterSntra91 is offline   Reply With Quote
Old 08-27-2008, 09:44 PM   #2
projectRDM
projectRDM's Avatar
There is a difference. The ABS spindle has a drilled hole for the sensor to fit into and a threaded hole for the bolt securing it.
I have an ABS pair, used, need some sanding on the shaft but are otherwise fine.
FORMERLY R240NA
Old 08-27-2008, 09:46 PM   #3
SinisterSntra91
Want to sell? How much?
Old 08-27-2008, 09:46 PM   #4
projectRDM
projectRDM's Avatar
Yes. PM me for info.
FORMERLY R240NA
