Old 09-03-2008, 11:08 AM   #1
Volchok
Volchok's Avatar
Volchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to behold
Send a message via Yahoo to Volchok
Water pump bolts, clutch fan
Rather novice question...
I recently changed from an electric fan to a clutch fan on my 92 S13, and one of the bolts that hold the water pump pulley on broke while removing it. With the clutch fan attached there is not much thread available for the nut to grab. I haven't removed the water pump yet.
My question is two part: 1.) are the bolts easily replaceable or is it welded to the pulley itself? if so anyone know what size the bolts are? and 2.) is the proper way to attach the clutch fan with the stock bolts? or do most people replace them with a longer bolt.
thanks in advance for any assistance.
Volchok is offline   Reply With Quote
Old 09-03-2008, 11:13 AM   #2
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
The bolts are the stud type bolts, they screw all the way out of the pulley. Unless somebody changed yours, it should have been a nut on a stud. Just get the rest of the nuts off, take the pulley off, and get the rest of the broken stud off with some pliers.
ryguy is offline   Reply With Quote
Old 09-03-2008, 12:43 PM   #3
Volchok
Volchok's Avatar
thank you, that is what I was hoping. how bout that second part...is it normal to reuse the stock studs or common to replace with a longer one?
thanks!
Old 09-03-2008, 12:56 PM   #4
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
when i had mu clutch fan i just re-used the stock studs
japslapsilvia is offline   Reply With Quote
Old 09-03-2008, 01:00 PM   #5
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
reuse it.......
Old 09-03-2008, 01:11 PM   #6
Volchok
Volchok's Avatar
cool thanks everyone
ziliva is the best....
Old 09-03-2008, 01:38 PM   #7
projectRDM
projectRDM's Avatar
M6x1.0, you can use bolts instead of studs if you want. Either way works fine.
FORMERLY R240NA
Old 09-03-2008, 01:47 PM   #8
Volchok
Volchok's Avatar
PERFECT! thanks so much I was hoping to get a size so I can pick 'em up prior to removing the old stud.
much appreciated!
Old 09-03-2008, 02:18 PM   #9
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
Reusing water pump studs: to remove, screw on one nut and then a second nut to hold it in place. turn the inner nut and the stud will come off.
Dont screw the first nut too far down or it will wedge. to screw stud into new pump, screw one nut in and then second nut. Use the outer nut to screw stud in
surreybc is offline   Reply With Quote
Old 09-03-2008, 02:24 PM   #10
surreybc
i forget what they are called but those ratchet wrenches probably work well for those 10mm nuts. they are skinny enough to use. like a normal open end wrench but ratchet in the opposite end.
