Old 09-09-2008, 06:15 PM   #1
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
2 Questions: One E-brake/One steering wheel wobble.
I just put these hubs on from my other car. Anyway the car rides fine til you hit 30 mph an hour then the steering wheel shakes violently back and forth. Any idea what that might be?
E-brake
My e-brake block (the thing the lines connects to) is rusted and I can't get the old lines off. I'm trying to install 300z e-brakes on. I ran them through. Do I have to make a custom connection to the e-brake handle or something? I tried the nissan site but can't find the e-brake block for sale. Any ideas would be appreciated.
rocksteady_racer is offline   Reply With Quote
Old 09-09-2008, 07:34 PM   #2
g6civcx
g6civcx's Avatar
Check tension rod bushings.
Old 09-09-2008, 08:27 PM   #3
projectRDM
projectRDM's Avatar
Retorque the bearing nuts. Sounds like you put them on with your fingers.
FORMERLY R240NA
Old 09-09-2008, 08:39 PM   #4
g6civcx
g6civcx's Avatar
Hubs as in 5-lug hubs or steering hub for aftermarket steering wheel?
Old 09-10-2008, 11:38 AM   #5
rocksteady_racer
Hubs
They are ichiba hubs off my other car. It's making a grinding noise from the front now. They are ichiba 5 lugs but I think maybe the bearings went already or something. They are torqued to spec I checked 3 times. What bearings can be swapped into those? Or do I have to get another set of hubs? They only have like 5000 miles on them. It doesn't make any sense. It has the washer too for those who think it's that cause I just doubled checked that too. The torque spec is 160 right?
Old 09-10-2008, 11:50 AM   #6
Sileighty_85
Sileighty_85's Avatar
Replace the bearing with REAL OEM ones
I heard lots of things about Ichiba's bearings crapping out soon after install
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-10-2008, 11:55 AM   #7
rocksteady_racer
Real OEM ones
As in real OEM ones I just have to get regular 91 240sx wheel bearings right? Not 300zx ones or anything right? The bearings are the same as stock in the ichiba hubs right?
Old 09-11-2008, 09:32 PM   #8
rocksteady_racer
Ok I figured out most of my problem
The tension rod on the one side is bent or something because the caster is off on one side. That's one of the problems. The other is the wheel bearings like I suspected. I looked on courtesy. I just need the [40210] BEARING ASSY-FRONT WHEEL
Fits this vehicle: 240SX (S13)
* 1989-1994 SELECT USE NTN & SELECT USE NSK
* 02/1989+ SELECT USE NTN & SELECT USE NSK
to replace the bearings in an ichiba hub on a 91 240sx, right?
CourtesyParts :: [40210] BEARING ASSY-FRONT WHEEL - 240SX (S13) 1989-1994 SELECT USE NTN & SELECT
Thanks in advance for all your guys help.
Old 09-11-2008, 11:10 PM   #9
rocksteady_racer
bump
bump
&msglength
