Old 08-13-2007, 12:24 PM   #1
lonelydrifter
lonelydrifter is making a name for him/her selflonelydrifter is making a name for him/her self
RAS install.
Hey when you install your Rocker Arm Stoppers are you still able to use that OEM copper cam plate on the exhaust side? I couldn't get it to fit with the new cams and RAS along with oil squirters.
lonelydrifter is offline   Reply With Quote
Old 08-13-2007, 12:41 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
You don't need it. Search for some RAS install threads.
Old 08-13-2007, 12:53 PM   #3
QuikS14
QuikS14's Avatar
QuikS14 is an unknown quantity at this point
I trimmed mine with a dremel since I used this DIY:
http://www.nicoclub.com/articles.php?id=224734
QuikS14 is offline   Reply With Quote
Old 08-13-2007, 01:00 PM   #4
Wahl 136
Wahl 136's Avatar
Wahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to all
I'm pretty sure that thread is only in Premieland.
Wahl 136 is offline   Reply With Quote
Old 08-13-2007, 01:27 PM   #5
lonelydrifter
Alright thanks guys I just wasn't sure what it was used for and if I really needed that thing. Now that I know it just for blow-by i'll just leave it off since im running and catch can anyways.
Old 08-13-2007, 01:35 PM   #6
Wahl 136
Wahl 136's Avatar
GL let us know if it worked out or not.
Old 08-05-2008, 03:48 PM   #7
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
hey sorry to jack your thread for a little but i was going to the ras install tomorrow and i just had a few questions.
first do i really have to empty out all the oil?
second if i dont have a torque wrench can i just snug it down?
and third i have never took off my valve cover so do i have reseal the whole valve cover or is the gasket enogh?
thanks and sorry about jacking your thread
moses is offline   Reply With Quote
Old 08-05-2008, 03:58 PM   #8
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
1: no you dont have to drain your oil
2: a torque wrench is a MUST.
3: a little rtv on top and below the vcg is always good, they tend to leak without it
aNskY is offline   Reply With Quote
Old 08-05-2008, 03:59 PM   #9
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
If you've never removed your valve cover and are asking if you need to follow torque specs on your valvetrain, this might not be the job for you.
The writeup mentioned above from Nico has plenty of directions/pictures that you should use it as your guide. Like he says, follow FSM procedure for cam cap bolt loosening/torqing and you should be fine to use your existing valve cover gasket, unless it's already leaking. Just make sure it's not twisted or ripped when reinstalling. Careful to not drop anything inside the valvetrain either.
You shouldn't have to drain oil....unless you just happen to be putting fresh oil/filter in anyway.
bshotts is offline   Reply With Quote
Old 08-05-2008, 04:01 PM   #10
moses
alright thanks guys. ill wait for the torque wrench and rtv.
Old 08-05-2008, 04:03 PM   #11
bshotts
bshotts's Avatar
Good luck and good choice for a first mod.
Oh yeah, a reliable and accurate torque wrench should be your new friend....go treat yourself to one you'll never look back!!!
Old 08-05-2008, 04:18 PM   #12
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
added questions, what if i have an S14 SR with the VVT can i install the same RAS's and if so is it the same install process or what? searched found only S13 schtuff...
INeedNewTires is offline   Reply With Quote
Old 08-05-2008, 04:21 PM   #13
aNskY
vvt unit is part of (in front of) the cam sprocket and the ras dont touch the cams so i dont see how it would be any different
Old 08-05-2008, 07:30 PM   #14
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
you have to trim a little bit on the vc for the s14 motor
sbanzer123 is offline   Reply With Quote
Old 08-07-2008, 03:21 PM   #15
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Technical Articles: Installing Greddy Rocker Arm Stoppers on SR20DET
x2 - I also trimmed my oil baffle with a dremel.. takes 10 minz - goodluck
BiG MiKE86 is offline   Reply With Quote
Old 09-27-2008, 11:59 AM   #16
Kuzumi
Kuzumi's Avatar
Kuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of lightKuzumi is a glorious beacon of light
Send a message via AIM to Kuzumi Send a message via Yahoo to Kuzumi
i appologize for bump but i have a serious question. Is there any specific way to install the ras with the spacers that are on the oil squirter? couldn't find anything online. today i started my car up and sounds like the rocker arms are hitting the stoppers.
Kuzumi is offline   Reply With Quote
Old 09-28-2008, 09:33 AM   #17
sbanzer123
sbanzer123's Avatar
i hate how people have to appologize for a bump to ask a question on an old thread but if you start a new thread you get bashed for not searching
