![]() Join Date: Nov 2002
![]() Ok, well as some as you know I am finally in the process of rebuilding my SR. Now I am going no-holds-bar on this and everyone keeps telling me to get my Crank Knife Edged. I'm already geting it ballence, I've had that done before but I have no Idea what knife edging does or what they do. If someone can give me some insite I would appreciate it. This may have been asked before but I don't have time to search for it. Thanks and happy driving.
Jim
'89 Fastback SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust. GT 16" rims, Walbro high Pressure fuel Pump, 7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods. |
![]() Join Date: Nov 2001
all it means is that they turn more material off the crank. The chops end up really sharp like a knife. It's a rotational weight reduction thing and it does make a difference. It's not quite as much weight as a flywheel, but it does make a difference.
Adam '89 coupe KA24DE+T 14.1 @ 104 MPH '88 Celica All-Trac turbo stock, but no more ecu codes!! |
its also believed that by knife edging it, it will decrease resistance when the crank moves through the oil.
1991 240sx coupe w/ ca18det Bone stock Purchased but not installed parts: HKS adjustable timing gears Electronic Oil Pressure Guage Apex'i Multichecker t3/t04b turbo Stainless Steel, top mount tubular manifold ARC bov 450cc injectors Spearco FMIC |
imagine a fat guy swimming. thats what you stock crank is like. now imagine a skinny guy swimming. alot less drag and resistance, right? thats a knife edged crank. the leading edge is sharpened like a knife, so it slices through the oil much better. its really effective on high revving engines.
![]() ok thanks guys. That helps me out alot. Guess I'll have to dish out another cuple hundred bucks.lol Later
Jim
#7 | |
![]() Join Date: Nov 2003
I don't know but it sounds cheap,$100-200...just doesn't sound right to me...but hey,if it is than I'm definitely getting my crank knife-edged soon ! What benefit would it be to get the crank balanced though ? I know that if you take off your stock dampner for aftermarket pulleys it supposedly will eat your crank b/c no balance,....After its balanced...does that not matter ?
I want to have the most efficient componets I can have...so I am definitely planning on running knife-edged,but I don't know what balanced does....I know that the 4G63E Mitsu boys are really big into knife edging... |
AutoX Junkie
The original idea of knife-edging back in the 70's was to reduce crankcase "windage" by sharpening the leading edge of the counterweights. Aside from the fact that you're lightening the rotating assembly, I think it's doubtful that it provides any benefit. It's pretty common knowledge that the most aerodynamic shape has a blunt leading edge and tapers to a sharp tail...not the exact opposite. Sharpening the trailing edge may actually affect windage...otherwise, it's just weight reduction. But remember, those are counterweights...if you lighten those, you must lighten the rods/pistons.
The more important thing to do is balance the assembly. If it turns out you're counterweights are heavy, it might be a good opportunity to knife-edge. Just make sure it's all balanced when done...a very small amount of metal can have an equivalent weight of several hundred pounds when being subjected to the accelerative forces found inside an engine. Making sure everything is balanced decreases bearing loads and just makes things run smoother and with more reliability. |
#13 | |
This was for a honda motor a while back, I found out that it wasn't neccessary anyway so I never went through with it.
#14 | |
![]() Join Date: Oct 2002
