Old 10-06-2008, 07:48 PM   #1
1qikhatch
1qikhatch's Avatar
1qikhatch is an unknown quantity at this point
s13 fuel delivery probs
ive checked my walbro by hooking a direct positive to it, it comes on. But when i just try to start it with the key the fuel pump does not kick on. does anybody have any idea what could be causing this?
1qikhatch is offline   Reply With Quote
Old 10-06-2008, 07:49 PM   #2
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
check all the wires leading to the pump?
renegade_ewok is offline   Reply With Quote
Old 10-06-2008, 10:26 PM   #3
projectRDM
projectRDM's Avatar
Pull the EGI pump relay and ground the black/pink lead, does the pump come on? If not, the relay or the fuse for the relay is bad, or the output wire is damaged somewhere. If it does, the signal from the ECU has been interrupted or the ECU is bad.
FORMERLY R240NA
