Old 10-12-2008, 04:45 PM   #1
nismo_drifter
nismo_drifter is on the path to ruinnismo_drifter is on the path to ruin
starter signal fuse keeps blowing out HELP???
okay everything was fine in my s14 until i installed a walbro fuel pump...i got it in and the car would not start anymore so i check out all the wiring and it was good...so i then checked the fuses in the car by the clutch pedal and the starter signal fuse was blown, it is a 7.5amp fuse so i replaced it and it went out again???i then tried a 10amp fuse and it also went out...
so i stop and that and wanted to get someone elses suggestion on what is wrong???i didnt want to go bigger then a 10amp fuse...
nismo_drifter is offline   Reply With Quote
Old 10-12-2008, 04:51 PM   #2
Sileighty_85
Sileighty_85's Avatar
your harness is grounding out somwhere
Double check for no exposed wires
Do not use any fuse higher then what is suppose to be there you will cause more damage if you do.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-13-2008, 11:57 PM   #3
nismo_drifter
hmmm...checked it out and it looks fine...any other ideas out there???
Old 10-14-2008, 12:01 AM   #4
nismo_drifter
doubled post my bad...
Old 10-14-2008, 12:08 AM   #5
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
check to see that your walboro is grounded suffieciently.
i would personally run a new ground wire to a better ground.
i would also wire in a relay and a fused right off the battery 12v for the walboro.
cronux is offline   Reply With Quote
Old 10-15-2008, 12:43 PM   #6
nismo_drifter
okay i cant seem to figure it out so im going run a power wire straight to the fuel pump with a in line fuse 10amp...just wanted get your guys opinion before so i dont end up wasting my time and still have the same problem...lmk thanks
