Old 10-19-2008, 01:10 AM   #1
MissShiftS13
MissShiftS13's Avatar
MissShiftS13 is an unknown quantity at this point
Send a message via AIM to MissShiftS13
s13 Z32 Maf and Titek 550cc injectors+Apex AFC Neo
Does any1 know what i do so my AFC Neo can recognize the injectors and maf so i can do this myself andnot get overcharged by having some1 else do it.....Please Help!!!! And no i cant affor a Power FC...
MissShiftS13 is offline   Reply With Quote
Old 10-19-2008, 03:41 AM   #2
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
Step one.
Get a Wideband O2 sensor.
We'll continue from there.
Until then, don't drive your car.
It will run retardedly rich.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-19-2008, 04:15 AM   #3
steve shadows
steve shadows's Avatar
Originally Posted by Addicted2Kouki View Post
Step one.
That's incorrect, if they are in fact the exact same valve/style of injector the car should run and driver pretty normally.
It will get crappy gas mileage, but under load should drive surprisingly smooth.
550cc is not a big enough jump to really mess things up
You will need to set the AFC to communicate the Z maf though, this needs to happen either wya.
Like Me on FaceBook !
Old 10-19-2008, 04:27 AM   #4
Addicted2Kouki
So you are saying...
without a tune... it won't run too rich and thin out the oil after driving it a bit?
I'm not trying to argue with you steve.
This is something you obviously know a lot about.
I'm just saying driving around with injectors that didn't originally go with the mafs and stock ecu won;t run so great and would be rich.
Old 10-19-2008, 10:15 AM   #5
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
i like the neo for super fine slight adjust tuning. recommend send out your ecu to get reflashed like enthalpy or jwt then like he said use the wideband o2 to get readings so you know how to adjust the ratios. without the gauge the afc is pointless.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 10-19-2008, 10:23 AM   #6
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
you are running 50% fuel overlap with the 550s... draw down the fuel maps by 40% (will be rich) from 0-3000 rpms... youll be able to limp to a dyno on that
as for the z32 maf.. you have to go into the in/out settings of the car and enter in the correct settins for the maf
((sr)) kelly is offline   Reply With Quote
Old 10-19-2008, 11:18 AM   #7
MissShiftS13
Also i have a Mines ECU on my car but not sure what it is set toor what makes it a Mines other than its well Mines, lol. Does any1 have any knowledge on those things?
Old 10-19-2008, 12:17 PM   #8
Addicted2Kouki
I don't think you are gonna be able to find out what the exact tune is, unless it is already written somewhere around or inside it.
Old 10-19-2008, 05:59 PM   #9
steve shadows
What is this thinning out the oil business? Pray your piston rings are not that worn to incur fatal oil failure after standard 2-3000 miles.
Large injectors cars ofen blow fuel past the rings after 1000 miles even with proper tuning.
It is not advised to drive around with 550 cc injectors in your car without direct fuel tuning (ie power fc or injector lag time adjustment as well/ems).
The Apexi , neo or not is just a device the confuses the air flow signal. THere is nothing minute or tiny in the adjustments at all. In reality under controlled conditions the changes to AFR are extremely sporadic and un-checked. I have proven this time and again with dual widebands hooked up to the car and monitoring AFM voltage changes/drops etc caused by the AFC.
Get your car tuned properly for the 550 cc injectors as soon as possible, but your car will be "driveable" in the mean time if you need to limp it by a couple hundred miles until you can get it on a dyno or tuned with a data logit
Old 10-19-2008, 07:03 PM   #10
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
agreeing with steve. get a rom tune at least.
Ignition timing is determined based on engine load. Load is calculated via maf and tps voltages plotted against rpm. therefore if you use an AFC to mess with maf voltage, you're artificially adjusting ignition timing.
not that i know anything about tuning but it seems like using an afc is "doing it wrong"
neilsan is offline   Reply With Quote
Old 10-19-2008, 08:16 PM   #11
MissShiftS13
How much would a rom tune dent my wallet?
