Old 11-14-2008, 12:41 AM   #1
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
s14 S14 SR Blitz Twin Plate Clutch issue
S14 Sr20det
Blitz active twin plate clutch (s13/14)
Just got my new cluch installed but have a serious issue,
it is extremely hard to put into first gear sometimes impossible, ill try like 5 times pump the clutch and try again pushing really hard till it actually slips into gear.
, 2nd,3rd and so on are a bit easier, basically once its moving it is possible to keep shifting gears the problem is when the car is stopping or still.
also very hard to pull out of gear when coming to a stop, sometimes it just wont come out of gear, and the motor is still pulling the car forward, till i am able to force it out of gear or turn the motor off to be able to get it out of gear..
I know this isn't normal.
we just re-routed the line from master cylinder to go straight to the slave cylinder, but it didnt help at all..
thinking of getting a new Z32 slave cylinder.
since my current one is still the stock one.
but i dont want to go around buying part after part if am not sure of what is causing this issue.
Has anyone else seen or had this kind of problem before?
tips? advice?
if I left any important info out just ask.
any help is appreciated!
Gabe
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 11-14-2008, 12:51 AM   #2
Dousan_PG
Dousan_PG's Avatar
drive for awhile
it will get smoother
gotta break it in some
Aaron
Pink GodziRa
Old 11-14-2008, 01:05 AM   #3
GabeS14
GabeS14's Avatar
Originally Posted by Dousan_PG View Post
drive for awhile
thx.
you know, my buddy said It might get smoother too, but it is soo rediculously hard to put in gear, probably takes like 40lbs of force to push in...lol
and thats when it does even go in gear.
and the people i know that have twin plates said their clutches were very stiff but never had the issue of not going into first gear..
Old 11-14-2008, 10:01 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
That's seriously bad for your syncros. How's the pedal feel? What slave cylinder does blitz say to go with?
A few of the twin plate clutches need more "throw" from the slave cylinder - that definitely sounds like your problem. The slave is not pushing the fork far enough to disengage both plates.
Of course, engagement is the one thing that changes as the clutch breaks in, so if Blitz doesn't require a Z32 slave, maybe you just need to drive it a few hundred miles.
Old 11-14-2008, 10:14 AM   #5
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
did you get the right tob?
you cant use a stock tob on multiplate clutch's.
it might not be disengaging the clutch all the way.
also you might have broken you pivot and the fork might be misaligned.
lok is offline   Reply With Quote
Old 11-14-2008, 10:16 AM   #6
GSXRJJordan
The throwout bearing comes in the kit, right Gabe?
It's also pretty difficult to misalign the fork and still have everything go in and "work", usually you notice when you bolt on the slave and the "nipple" doesn't go right into the fork's cup.
Old 11-14-2008, 10:52 AM   #7
nzmoman
nzmoman's Avatar
nzmoman is an unknown quantity at this point
it seems like you need to put in a tech call to Blitz. I have blitz unit on my car and the TOB has given me problems and I think it is going to be on its way out again. I would call them and ask specific questions, and be careful about driving until its resolved...its better safe than having to source new drivetrain components.
nzmoman is offline   Reply With Quote
Old 11-14-2008, 11:08 AM   #8
vespaman
vespaman's Avatar
Trader Rating: (64)
vespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to behold
Feedback Score: 64 reviews
same thing happened to me when i installed blitz active single plate clutch with stock SR TOB and sleeve. i ended up get a new TOB and sleeve from ORC thorugh RHDjapan.com and i relized after that that the TOB completly different also the sleeve can't rememeber if the stock sleeve is shorter or taller.
vespaman is offline   Reply With Quote
Old 11-14-2008, 11:52 AM   #9
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
i have similar problems with OGURA clutch . first days (week 1 -2) it was pretty rough. i also adjusted the pedal and that help the engagement on 1st gear like u having... right now is a lot lot better but if someone drive my car for the first time they usually have a hard time ..
so ill say try to adjust ur pedal.. my slave is going bad btw...
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 11-14-2008, 12:50 PM   #10
GSXRJJordan
Pedal adjustment - didnt' think of that. Good idea ~ give that a try first, hell, it's free!
Old 11-15-2008, 01:10 AM   #11
GabeS14
GabeS14's Avatar
thanks for all the posts..
and tips..
The Clutch usually does come with a TOB and sleeve i think but mine didn't..
i bought a TOB made for twin plate clutches from local shop though.
Whats up with the sleeve?
there is a specific one for twin plates? if so it could be that since i did not know i needed a specific one.
would it affect the engagement?
I am thinking of getting a z32 slave cylinder mine seams a bit weak...
also am going to try to adjust the clutch pedal seams liek a smart thing to do!
Old 11-15-2008, 09:48 AM   #12
Sileighty_85
Sileighty_85's Avatar
Stock TOB/sleve Left
OS Giken Twin Plate TOB/sleve Right
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-15-2008, 12:23 PM   #13
GSXRJJordan
If his Blitz twin plate required a shorter sleeve, he'd have the opposite problem - the clutch would always be disengaged, because the stock sleeve/TOB would be permanently pressed into the pressure plate, right?
I'd say give Blitz USA a call, they're in City of Industry/Walnut, and have normal biz hours - I've used them for some boost controller troubleshooting and they're pretty good once you actually talk to a "tech" guy.
Old 11-15-2008, 08:07 PM   #14
GabeS14
GabeS14's Avatar
Thanks for that!!
mine didnt come with one, the guys that sold it to me didnt have it ... but usually the blitz twin paltes come with one, so i think that is a possibility!
Yea I did some research yesterday and found their adress and number, ill call monday!
By the way i do have a lot of trouble putting in gear, and when it does go in gear then it doesnt wanna come out anymore..lol
so it could be that!
Old 11-15-2008, 08:16 PM   #15
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
you should stop driving it, the clutch is not fully engaging or disengaging.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 11-18-2008, 07:50 PM   #16
GabeS14
GabeS14's Avatar
Blitz told me they dont sell or fabricate the Release sleeve for this clutch anymore...
So I spoke to C-Unit and he said that OS Giken makes the clutches for Blitz so he is trying to contact them to find out the right sleeve size and place the order for me.. they should have an equivalent!
hope this does it..
Old 12-10-2008, 10:37 PM   #17
GabeS14
GabeS14's Avatar
Guys..
I wanna ask for everyone's help..
I got the part number but it seams no one has it.. I contacted Nissan and they have it backordered with no ETA..
help..!!!lol
If anyone knows where and how to get ahold of this nissan part. #:it is orderable in many websties but they dont actually have it in stock.. it is going to be backordered..so i need to find someplace that actually has it in stock
30501-b6000
please let me know.. maybe some small specialized shop may have it in stock.. its a OS Giken release bearing for S14 SR20det.
I also contacted Aspec logan is contacting OS to see if maybe they have it in stock
Old 12-10-2008, 10:57 PM   #18
GSXRJJordan
Whoa, that sucks! Tried Courtesy, Performance and WestCo Nissan? Those are the three that I know of that always have the JDM shit in stock.
Old 12-10-2008, 11:28 PM   #19
Om1kron
Om1kron's Avatar
It took me a month to get a STOCK throw out bearing from performance nissan. So dont hold your breath.
Wayne Edwards
https://om1kron.blogspot.com
Old 12-10-2008, 11:32 PM   #20
GabeS14
GabeS14's Avatar
Im'e gonna call West-co either justin or Ray ..hopefully they have it in stock but i doubt it.
its kinda rare.
Old 12-10-2008, 11:38 PM   #21
wgJoY
wgJoY's Avatar
wgJoY is an unknown quantity at this point
Send a message via AIM to wgJoY
WestCo Nissan always has the JDM shit in stock.
Or if not, give 'em two days. They hook it up yo.
I'm sure your bound to run into it somewhere. Just put the word out everrrryyywhere, you'll get a call or something sooner or later.
you have a DD in the mean time or is your 240 it?
wgJoY is offline   Reply With Quote
Old 12-11-2008, 12:35 AM   #22
GabeS14
GabeS14's Avatar
No DD. my 240 is it.. i live close to work, like 5 min driving..but have to get 2 buses to get there or walk 25 minutes..lol
weird thing is that Nissan North america says the part is not available anywhere.. it is impossible that no one has this release sleeve being that it is used for many different clutches..even R34s use the same part.
Old 12-12-2008, 04:34 PM   #23
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
So wtf do you need again? hahaha. My OEM SR throwout bearing had a trumpet style face to it.. It was longer than the OEM KA ones people use. Much different. Same for the sleeve. Clarify what you need. I have a sleeve that came out of an OE SR trans which was actually longer than the OEM KA one I bought.
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 12-12-2008, 05:17 PM   #24
drftwerks
buy a bicycle.
giantroboteyes.wordpress.com/
Old 12-13-2008, 11:06 AM   #25
GabeS14
GabeS14's Avatar
-Bart
Originally Posted by drftwerks View Post
buy a bicycle.
I need the RElease sleeve .
I talked to Ray from West Co nissan and he found out the part number was originally for a Datsun 810 2.8 liter diesel motor and then i called Kragen and they make a part for it too,only $26 bucks... so I am on my way to pick it up I am hoping it is the right one..
I also finally found a place that sells the OS Giken one, in Australia..........lol but its $132.00 plus $40 for shipping
Old 12-13-2008, 12:47 PM   #26
GSXRJJordan
Whoa, cool! If you can get it from Kragen, all the better! Keep us posted!
Old 12-15-2008, 09:34 PM   #27
GabeS14
GabeS14's Avatar
i wish i could find a picture..because the one from Kragen looked weird, very diffreent then the stock one.. looks like a spray can cap.
but then again, i never saw this one so maybe they do look different.
ill keep you guys posted..
Old 12-15-2008, 09:51 PM   #28
GSXRJJordan
Haha, LuisGonz and I were just talkin about you today. Neither of us can believe you're still having this problem. Good luck man!!!
You know, until you roll out to the meets again, I think I have the fastest S-chassis there every time lol.
Old 12-15-2008, 09:54 PM   #29
240srhatch
240srhatch's Avatar
240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold240srhatch is a splendid one to behold
make sure when you install the new parts on your car that your clutch fork is properly installed. I had a problem with my fork coming off from one side and i couldnt get into gear, it ended up being the clip that holds the fork in place.
240srhatch is offline   Reply With Quote
Old 12-15-2008, 10:36 PM   #30
jdmkings
jdmkings is an unknown quantity at this point
Gabe, All of blitz clutches are made by ORC (Ogura Clutch). The part you're looking for is pretty easy to order. Any ORC dealer can get it for you. You are looking for the sleeve and bearing assembly for the ORC 559D twin clutch for S13/S14 SR20DET. The blitz part number is in their 07 Power Book, but i'm not sure if they can still get it since they changed over to the carbon clutches. Either way, i'm sure you can get the part from any ORC dealer. You can try Nengun performance or Bulletproof automotive. They can probably get it for you. Hope this helps.
http://www.paramo.jp/view_pamph.php?client_id=ogura&pamph_id=product200 6&page_no=1〈=en
go to page 16 (click on the right arrow)
jdmkings is offline   Reply With Quote
