Old 05-05-2003, 09:13 PM   #1
Crab Spirits
Crab Spirits is an unknown quantity at this point
Send a message via AIM to Crab Spirits
SR Problem with using SR's HICAS pump?
Can I use the SR's HICAS steering pump on my non-hicas car? I know there are 2 pressure ports instead of one. Can I just plug one? If not, can I just route it back through to the resevoir? Or will the pressure just blow all the oil out?
JDM fun
Crab Spirits is offline   Reply With Quote
Old 06-05-2003, 06:56 PM   #2
justeno_heat
justeno_heat is an unknown quantity at this point
Send a message via AIM to justeno_heat
No you can't just block it because it has a device to pump out fluid when it is needed and if it can't it will brake. As far as bleeding it to the resevior you can try that but it takes some confuring. Take my advice just go without it. It really isn't bad. The only hard turning is when you are sitting still. Plus it is a light car it ain't hard to turn trust me.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
2 10" JL Audio W3's with Kenwood head unit
Erebuni carbon fiber hood
Koyo aluminum radiatior
240 down for the Summer FROWNING
If NISMO stands for Nissan Motorsports, wouldn't Honda Motorsports be HOMO?
justeno_heat is offline   Reply With Quote
