Old 12-03-2008, 07:04 AM   #1
silviakid2790
silviakid2790 is an unknown quantity at this point
question about my sr20 hesitating... could it be from lo oil pressure?
my sr20 recently started having a problem with hesitating under boost... mainly 3rd gear pulls..but it has acted up in every gear
its almost like power is being shut off to the coils for a split second then it will climb a little higher in the rpms and studder again..
my car has low oil pressure as well. because i have a leak at the feed line.. i hate that dumbass banjo setup..
my question is, does the sr20 have a "limp Mode"? im wondering if my ecu is killing power to my coils because its reading a weakoil pressure
silviakid2790 is offline   Reply With Quote
Old 12-03-2008, 07:15 AM   #2
Nduggs
Nduggs is an unknown quantity at this point
If you are getting hesitation, the timing is the first place I would look. Try moving your CAS around a little bit.
Nduggs is offline   Reply With Quote
Old 12-03-2008, 07:17 AM   #3
silviakid2790
nah the timing is fine...
also i have a mixture of weights in the oil because i ran out and had to put 5w30 in it
Old 12-03-2008, 09:47 AM   #4
Sileighty_85
Sileighty_85's Avatar
Check your ECU for codes and then clear them,
I noticed mine had a code for CAS and Knock Sen, once when I had a Slute pop off, misfired in first gerar and sometimes around 10-25% throttle cleared he codes and it went away after 20 mins of driving
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-03-2008, 10:11 AM   #5
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
actually it make more sense that he has a big boost leak and thats where the first place he should look cuz i've been there before and know exactly what he's talkin bout
SILVIA_KIDs14.5 is offline   Reply With Quote
Old 12-03-2008, 01:23 PM   #6
Nduggs
I was just trying to help identify a problem. Now that I think about it, a timing issue would act up all the time. So you think he has a major boost leak, sometimes? Mainly in third gear? haha
Old 12-03-2008, 02:32 PM   #7
silviakid2790
think i found out what it was...
the line coming off my PCV valve that goes to the back of the block poped off at the block ... i think thats what was doing it
