Old 05-12-2003, 09:37 AM   #1
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
s13 Rear hub removal
Well I am in the midst of my 5 lug swap and brake upgrade.
The rear hubs seem to be pretty well fused with the upright. I have removed all 4 bolts as well as the 36mm axel nut. However the hub is still stuck tight. I think that all the years of heat and rust have fused the 2 (if such a ting is possible). The axle moves in and out freely and there is nothing else that I can think would holding them together. I am going to remove the axel next, and take the BFH to the hub to break it lose. If any one has any tips or tricks for breaking these lose please let me know :-D
Lurker Supreme!
www.midatlantic240sx.com
  • 91 Coupe
  • 97 KA24DE+T SOLD
uuninja is offline   Reply With Quote
Old 05-12-2003, 09:45 AM   #2
Dousan_PG
Dousan_PG's Avatar
there are 4 bolts and the axle bolt
to pull it off you need to try a few things
1: try and pull the hub off. maybe hit it with BFH a bit to 'break' it loose (not break in reality break like snap in 2 but break the rust free--if any)
2: liquid wrench that mofo. drown it
3: last resort: drop the diff, use axle puller and push axle out. the hub willl now drop free
Aaron
Pink GodziRa
Old 05-12-2003, 09:50 AM   #3
uuninja
Axel slides in and out with just thumb pressure so it is the splines are not rusted to the axel. That should come out easy, doubt I will even need an axel puller. The more I think abou it I think that having the axel in there absorbes some of the blow from the BFH instead of letting the rust between the hub and upright take the shock. I think if I remove the axel I should just be able to give it one good wack and break it lose.
Lurker Supreme!
  • 91 Coupe
  • 97 KA24DE+T SOLD
Old 05-12-2003, 09:53 AM   #4
Dousan_PG
Dousan_PG's Avatar
ya should work
this is off s14/s13 right? not like a z subframe/upright..just wnat to make sure. z has extra bolt at top (top top) of upright/hub for the ebrake stuff.....that bolt was a PITA to get off. i'm glad i had an extra subframe to use or it would have NEVER come loose!!
yah liquid wrench it, wd40, whatever to get it loose. if you dont care about the hub then set something up to hit it hard from top and break it.
just dont crack your upright
Aaron
Pink GodziRa
Old 05-12-2003, 10:01 AM   #5
uuninja
the hub and upright on the car are the stock s13. I was relieved to find out that the 27 mm bolt on the z upright is only used for the ebrake assy and is not on the s13 upright (even though the hole is). I had to take the whole Z32 hub and upright to a garage and have them use an air gun to get that one loose.
I am really surprised how stuck this thing is. I let it soak in wd40 over night, couldn't find my liquid wreanch .
Anyway thanks for the input.
Lurker Supreme!
  • 91 Coupe
  • 97 KA24DE+T SOLD
Old 05-12-2003, 10:03 AM   #6
Dousan_PG
Dousan_PG's Avatar
ya
if you let it soak thatlong
drop the diff, remove the axle and hit it out
if no luck, might want to take off the upright (DONT MOVE THE ECCENTRIC BOLTS LOCATED ON THE SUBFRAME) just unbolt it from the car and examine it. see what is going on
as long as you removed the 5 bolts, it should come off relatively easiyly
i just heavily stress NOT to remove the arms or change the eccentric bolts on the subframe. the parts that bolt to the upright have no eccentric bolt and you WONT be changing your car's alignment.
Aaron
Pink GodziRa
Old 05-12-2003, 10:07 AM   #7
uuninja
I hear you, thanks again.
Lurker Supreme!
  • 91 Coupe
  • 97 KA24DE+T SOLD
Old 06-14-2008, 12:29 PM   #8
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
i know this is very old, but this is not working for me. if i wack this hub any harder with this hammer i am afraid i am going to do damage to the bearings. any other suggestions?
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 06-14-2008, 12:40 PM   #9
an_orange_s2k
an_orange_s2k's Avatar
an_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond repute
i just did this the other day. use a rubber mallet to the backside of the hub and just whack it till it comes out. i sprayed wd40 all over it but i hear pb blaster(not sure if its the right name?) works a lot better.
an_orange_s2k is offline   Reply With Quote
Old 06-14-2008, 01:01 PM   #10
devonkyle77
i used pb blaster...hmm i will try that rubber mallet.
Old 06-14-2008, 03:23 PM   #11
devonkyle77
still no luck
Old 06-14-2008, 03:56 PM   #12
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
i had the same problem with z32's, just hit them harder they'll be fine.
aNskY is offline   Reply With Quote
Old 06-14-2008, 06:33 PM   #13
Howard92884
Howard92884's Avatar
Howard92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond repute
Send a message via Yahoo to Howard92884
Why not go rent a Hub Puller from Schucks or Autozone? Yes I know this hub is different but this same tool will work for your car.
Howard92884 is offline   Reply With Quote
Old 06-14-2008, 07:00 PM   #14
krisdeezy
krisdeezy's Avatar
krisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant future
Send a message via AIM to krisdeezy
^^ i think that's the best solution ! but what i did was... 1st axle nut, then i took the 4 bolts out in the back...after that i tried to hammer it loose but not enough leverage...so i was lucky and had a worn rotor sitting around and flipped it backwards bolted it on and hit that bitch out !!
krisdeezy is offline   Reply With Quote
Old 06-14-2008, 09:31 PM   #15
devonkyle77
its off the car though..
Old 06-15-2008, 08:43 AM   #16
devonkyle77
still nothing. i have broken two rubber mallets in two days beating the hell out of this thing. and my arm is sore from hitting it with a big f'in hammer so many times. by big hammer i mean a damn sledge.
