Old 12-08-2008, 03:24 PM   #1
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
JDM Fan controller
Here is the deal, dudes.
I picked up a big fat radiator for my car, right? yeah. right.
Also, I got a big fat electrical fan with it. cool. pun.
Now, here is what I want.
I'd like to get a wicked JDM fan controller for it.
I've been looking around just a bit for some and so far I have 2 options that I see.
I like the Pivot one.
The BILLION one I do not like because it looks like a 60mm gauge.
I think HKS makes one too, but it might have a sprayer kit or something.
My gooogle is being crap right now, so searching is hard.
Does anybody have a suggestion for me for a badass JDM fan controller.
I don't want USA junk.
http://bhworld.wordpress.com/
Old 12-08-2008, 03:26 PM   #2
projectRDM
projectRDM's Avatar
Pivot. Small, compact, some units double as a water temp gauge too. Very easy ti install and stash anywhere.
FORMERLY R240NA
Old 12-08-2008, 03:29 PM   #3
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
SARD
Sard Racing M.F.C. Multi Fan Controller#
HKS
HKS Fan Controller - HKS
Flicktitty is offline   Reply With Quote
Old 12-08-2008, 03:29 PM   #4
LongGrain
LongGrain's Avatar
i'm pretty sure greddy makes one, also DIF, but i'm not sure if DIF is usa or not.
i have heard good things about both.
if you want to be ultra JDM like me you can just run your fans to a switch
LongGrain is offline   Reply With Quote
Old 12-08-2008, 03:31 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
USA, JDM, etc.... ALL made in taiwan. Get the DIF dual fan controller, it's probably made in taiwan too but it's cheaper than the "JDM" made in taiwan stuff.
Old 12-08-2008, 03:32 PM   #6
Brian
Brian's Avatar
Trader Rating: (54)
yeah I saw the DIF on phase2..... never heard of it. I voted NO on it.
I thought about just doing a switch, but I need lights and bullshit.
PIVOT is in the lead so far. very basica and straightforward.
I already have a Yashio Factory temp gauge that I don't want to get rid of. Looks like it uses the EXACT same sensor as the Pivot (and GReddy for that matter)...
Old 12-08-2008, 03:33 PM   #7
LongGrain
LongGrain's Avatar
lights? what do you need lights for,
i thought you lived in cali where the sun shines 24/7
Old 12-08-2008, 03:34 PM   #8
Brian
Brian's Avatar
Trader Rating: (54)
lights. doodads.
bells and whistles....
Old 12-08-2008, 03:35 PM   #9
Brian
Brian's Avatar
Trader Rating: (54)
the SARD one is nice. JDM is good on it. But, it is a little too basic I think. Needs more doodads.
Old 12-08-2008, 03:36 PM   #10
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
greddy MSS, works great, you can use it for 2 fans, and stagger the temps at which the fans turn on, also you can use it for water temp.
you can also do one fan and a sprayer....or what ever else you want to trigger with, water temp, speed, or RPM.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 12-08-2008, 03:38 PM   #11
Brian
Brian's Avatar
Trader Rating: (54)
I only have one fan though. No need for 2 things.
No sprayer either....
Question.
With the Pivot one, it comes with water temp and then fan control at certain temp.
I want to keep the Yashio gauge (obvious trick points)... so can I run both things off the one water temp sensor? How would I do that?
Old 12-08-2008, 03:40 PM   #12
Brian
Brian's Avatar
Trader Rating: (54)
retail price is pretty low too...
I think this is what I might end up getting...
Old 12-08-2008, 03:41 PM   #13
LongGrain
LongGrain's Avatar
Question.
you can probably do that, you would just need to cut off the temp sensor on your fan controller and splice the wires into the wires for your yashio gauge.
i am no wiring guru or anything so dont quote me, but it sounds like it would work just fine.
Old 12-08-2008, 03:42 PM   #14
japslapsilvia
i would think you would have to use a Diode
BUT
you may just be able to tap into the CTS just like ur Yashio gauge
dunno if it will cause any interference
Edit
wait does the pivot run a seperate sensor?
and does the YF use stock CTS?
Old 12-08-2008, 03:42 PM   #15
Brian
Brian's Avatar
Trader Rating: (54)
yeah I assume thats what I can do... seems pretty solid and straightforward.
Also, the Pivot one gets priority because I have the Pivot headlight controller too...
Old 12-08-2008, 03:43 PM   #16
Brian
Brian's Avatar
Trader Rating: (54)
what is a "CTS"?
edit: oh i bet it is coolant temp sensor, huh?
Old 12-08-2008, 03:54 PM   #17
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
i was just gonna say that CTS...
just get the pivot one, pretty simple and im guessing that you can use the yashio toy thingy you so much want to keep... since it uses the same sensor, im guessing the stock one? you could splice it in 2 places and have them read from that same sensor... i don't know if this would affect the sensor... thats the only problem i would see if it does then your screwed if not, go for it...
bejota180sx is offline   Reply With Quote
Old 12-08-2008, 03:58 PM   #18
Brian
Brian's Avatar
Trader Rating: (54)
I'm pretty sure they both use this exact same sensor... that one in the bottom left corner. (I know GReddy uses the exact same one too).
I have the metal YF temp sensor adaptor too. The one you put in the rad. hose.
Old 12-08-2008, 04:01 PM   #19
japslapsilvia
greddy MSS uses stock CTS (coolant Temp sensor)
Old 12-08-2008, 04:03 PM   #20
Brian
Brian's Avatar
Trader Rating: (54)
CTS must be some stock thing, right?
I have no idea where that is or what it looks like.
Old 12-08-2008, 04:06 PM   #21
LongGrain
LongGrain's Avatar
yea when you see CTS it is referring to the stock coolant temp sensor.
that pivot fan controller with the water temp display is sweet, i think i might get one for my car.
Old 12-08-2008, 04:10 PM   #22
Brian
Brian's Avatar
Trader Rating: (54)
oh... for those that might tell me to just keep the stock fan..
on my s14 all I had was the AC fan. It turned on when I turned the car on. thats all.
Never had anything else. It seemed to keep the car pretty cool most of the time.
So, on my new car I will run a stock KA again, and I just got a big Spearco radiator. I figure I should probably not have cooling issues.
Old 12-08-2008, 04:13 PM   #23
projectRDM
projectRDM's Avatar
There's three different Pivot models, but I don't know which ones are still in production. Their site is hard to follow and most online retailers don't know the differences.
1) Uses the OE CTS, dual output for fans. Wire it all in right at the ECU.
2) Uses it's own sender, threads into a 1/8 BPST port IIRC, dual fan output.
3) Does both oil and water temp display, senders for each, dual fan output.
I have the second version, love it. Easy to use.
FORMERLY R240NA
Old 12-08-2008, 04:15 PM   #24
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
DiF works great, easy install, operates two fans on different temeratures. Use it on my ride with no problems.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 12-08-2008, 04:15 PM   #25
Brian
Brian's Avatar
Trader Rating: (54)
yeah the second one, thats what i want.
I think that is the picture I posted.
it SEEMS they are all discontinued.
Old 12-08-2008, 04:17 PM   #26
Brian
Brian's Avatar
Trader Rating: (54)
The DIF one looks terrible.
That is NOT an option.
Old 12-08-2008, 04:18 PM   #27
racepar1
racepar1's Avatar
The DIF one is mounted in the engine bay so you can't see it. I know you want another doohickey to play with in the car. :ghey: LOL
Old 12-08-2008, 04:21 PM   #28
Brian
Brian's Avatar
Trader Rating: (54)
oh god, in the engine bay?
what is the benefit of that? NOTHING.
Old 12-08-2008, 04:36 PM   #29
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
lol... Brain I can tune your ecu to have a fan controller for cheaps.
BUT no bells or whistles. but I can program a launch controller and a rev limter... there/s flames and fireball explosions!!! instead of lame ass bell and whistles toot toot.
lmk.
the pivot shit looks good.
but I am cheappppppppp, plus you know what my extra money goes too....lol
Peace brosefhhhh
sillyvia13 is offline   Reply With Quote
Old 12-08-2008, 04:39 PM   #30
Brian
Brian's Avatar
Trader Rating: (54)
Lol.... I can't handle tuned computers.
Stock KA or bust.
