Old 12-17-2008, 11:26 PM   #1
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
KA overheating, odd problem
so its winter time and my temp gauge was always fluctuating, either too cold, or normal operating temp.
so i thought my thermo was stuck open
i buy one from autozone, open it up, and i dont have one. so i put it in, right side in, with the jiggle valve on top.
run my car, overheats, no biggie, i jack the front up and bleed it for a while.
after a while or so, still over heating, so i take the thermostat and put it in a pot and heat it up.. it opens.. i put it back in
still overheating.. lower hose it cold, but the thermostat housing is hot.
i take the hose off, and there was barely any fluid coming out.. i take the radiator cap and it just pours out of the hose.. is that normal?
my car ran fine with the thermostat off, just cold and no heater..
1slowS13 is offline   Reply With Quote
Old 12-18-2008, 12:12 AM   #2
wht240sx
wht240sx's Avatar
wht240sx is an unknown quantity at this point
Is the coolant boiling over to the over flow tank??? actually bubbling??
wht240sx is offline   Reply With Quote
Old 12-18-2008, 12:33 AM   #3
10-66kruk
10-66kruk's Avatar
10-66kruk is an unknown quantity at this point
ive been having this same issues and am running a mishimoto aluminum radiator nismo thermo and am "over heating" wish i could figure it out as well.
10-66kruk is offline   Reply With Quote
Old 12-18-2008, 01:39 AM   #4
1slowS13
1slowS13's Avatar
yea it boils and flows into the overflow
im running no thermostat again just to get around
Old 12-18-2008, 08:43 AM   #5
wht240sx
wht240sx's Avatar
you might want to check your water pump. take it off and inspect it. Also you may need to pressure test you cooling system and see if you have leaks. Thats where i would start.
Old 12-18-2008, 08:53 AM   #6
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
what color is your coolent when you take flushed?
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 12-18-2008, 09:04 AM   #7
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Change out the Mishimoto radiator cap.
My friend's S13 did the exact same thing.
Turned out the cap wasn't holding pressure.
Replaced it with an OEM Nissan one...done.
No more overheating.
-Jspec-
Instagram/CrimsonRockett
Old 12-18-2008, 10:32 AM   #8
1slowS13
1slowS13's Avatar
the color was green, it was pretty clean.. like the p.o. said, he got it flushed.
also, when running no thermo, you can clearly see the water circulating..
Old 12-18-2008, 01:07 PM   #9
mikethebiker
mikethebiker's Avatar
mikethebiker is a well-known jackass
i would think the problems in your waterpump
inspect
mikethebiker is offline   Reply With Quote
Old 12-18-2008, 02:03 PM   #10
1slowS13
1slowS13's Avatar
so i went ahead and got another thermo from a different auto parts store, and instead of getting 50/50 for $8, i got some distilled water instead.
i put it in, drive it around, doesn't over heat.
im like cool, i pull into the garage and let it cool.
after a hour or so, i top it off and run it without the rad cap and with the bleeder loose.. take it for a drive, overheats again! wtf? im like fuck it, i pop the rad cap out and it was steaming, then i start the car, then a few seconds later it starts spewing water and coolant, so i throw the rad cap back on. drove it home to get some more water, but never overheated after.. i went around town, drove on the highway, and even went through a busy drive-thru and its fine. odd.
Old 12-18-2008, 07:56 PM   #11
10-66kruk
10-66kruk's Avatar
really? ya there seem to be a lot of steam coming from that area. Hope that's it, wouldn't have thought it would be something simple like that.WIll give it a shot thanks.
Old 12-18-2008, 08:41 PM   #12
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
how long are you leaving the bleeder open? Are you SURE you're getting all the air out?
holemilk00 is offline   Reply With Quote
Old 12-19-2008, 12:31 AM   #13
Norty
Norty is an unknown quantity at this point
ka is notorious for being hard to bleed. When bleeding jack the front up to help make sure that is the highest point and bleed that mother f*er till it the gauge is reading close to hot i used to have trouble with mine all the time. So ur not the only one.
Norty is offline   Reply With Quote
Old 12-19-2008, 12:56 AM   #14
92champgold
92champgold's Avatar
92champgold is an unknown quantity at this point
Send a message via AIM to 92champgold
water pump +1
92champgold is offline   Reply With Quote
Old 12-19-2008, 04:05 PM   #15
10-66kruk
10-66kruk's Avatar
Ya i will also have to try this again. How long are you guys keeping the bleeder open with coolant coming out? Also are you pouring coolant in the radiator at same time?
