Old 12-19-2008, 12:15 PM   #1
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
100 octane KA
I like riding in drift cars t hat run on race gas. 100/103/110 whatever...
Well, those guys all have SRs and high power stuff.
I have a stock KA.
Is it ok to run a high octane gasoline like that in my car?
I mostly want to do it for the smell. I like the aroma that comes off these cars.
So, any negatives to running a high octane gas like these?
http://bhworld.wordpress.com/
Brian is offline
Old 12-19-2008, 12:18 PM   #2
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
I have a feeling you're joking... but I want to ask anyway,
are you being serious or just playing?
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline
Old 12-19-2008, 12:20 PM   #3
I10cruiser
I10cruiser's Avatar
Trader Rating: (47)
I10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfectionI10cruiser is close to perfection
Feedback Score: 47 reviews
Send a message via AIM to I10cruiser Send a message via Yahoo to I10cruiser
i think ernie ran 110 or one of the dtc guys and i think might of blown there kae after a while. . high octane=win
I10cruiser is offline
Old 12-19-2008, 12:22 PM   #4
Brian
Brian's Avatar
Trader Rating: (54)
I'm pretty serious.
I don't think I'd want to run LEADED, right?
Unleaded only. I still have the cat in my car.
I don't want to use this gas everyday, but just put some in when I go to the track...
Brian is offline
Old 12-19-2008, 12:23 PM   #5
LongGrain
LongGrain's Avatar
a stock KA will not burn 100 octane efficiently
LongGrain is offline
Old 12-19-2008, 12:23 PM   #6
Brian
Brian's Avatar
Trader Rating: (54)
Yeah, I've heard that, but will my car run WORSE than if I put 91 or something in there?
Will that 100+ octane ruin my engine somehow?
Brian is offline
Old 12-19-2008, 12:28 PM   #7
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
100 octane will run worse. are you going for the scented race gas smell ? Like lavender or bubble gum? Cuz if thats the case you can just buy the additive and put it in your normal gas. Technically the lower the octane you can go without detonation is the best.
http://www.fuckdrama.com/
vvtisupra is offline
Old 12-19-2008, 12:29 PM   #8
Brian
Brian's Avatar
Trader Rating: (54)
I see....
Ok, I guess I won't run 100+ then.
I don't want to make my car run WORSE just for the good smell.
Maybe I could just spill a little around the car or something... give it a hint of race gas smell...
Brian is offline
Old 12-19-2008, 12:30 PM   #9
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
It will run less efficiently and you will lose a bit of power. You don't want to run any more octane than what is absolutely necessary. Higher octane = higher resistance to combustion = burns less efficiently = less power. I don't think it will permanently damage your engine though.
racepar1 is offline
Old 12-19-2008, 12:31 PM   #10
S14DB
AFC #1
S14DB's Avatar
You will be fine running any Unleaded Race Gas in your car. Leaded will kill your O2 sensor, Cat and leave deposits all over the spark plugs and the back of your valves.
Negatives is that it burns slower then lower grades. May not get complete combustion and lower your MPG. If you run colder plugs then stock check them after the first time. May need a hotter set for race gas. These are all minor things.
S14DB is offline
Old 12-19-2008, 12:32 PM   #11
LongGrain
LongGrain's Avatar
soak a rag or something in it and keep it in the car as an air freshener when you go to the track
but i would not recommend using it, ESPECIALLY if you have a cat.
Old 12-19-2008, 12:34 PM   #12
Brian
Brian's Avatar
Trader Rating: (54)
Yeah, looks like I won't be using it.
I have no desire to change things around. Putting gas into the gas tank is the most amount of work I want to do.
And, seeing as I have a stock engine, I don't want to LOSE ANY power.
Thanks guys.
Brian is offline
Old 12-19-2008, 12:35 PM   #13
usdm180sx
usdm180sx's Avatar
It's like $8/gallon at the 76 station in Fullerton
-Norm!
usdm180sx is offline
Old 12-19-2008, 12:38 PM   #14
McRussellPants
Thanks guys.
Put in Racegas
advance timing all the way
profit
McRussellPants is offline
Old 12-19-2008, 12:40 PM   #15
Brian
Brian's Avatar
Trader Rating: (54)
Lol lol
Advance timing? I have no idea how to do that.
Brian is offline
Old 12-19-2008, 12:44 PM   #16
S14DB
AFC #1
S14DB's Avatar
Just mix like 5galons of 100R and a full tank. Will give you the smell and only raise the Octane 3~4 points.
S14DB is offline
Old 12-19-2008, 12:44 PM   #17
driftking777
driftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of light
if you want a cool smell you could always run something like this
Manhattan Oil 19769-32 - Manhattan Oil Fuel Fragrances - summitracing.com
comes in grape and cherry
13 bucks will do 2 tanks of gas. and this shit is strong. we run it in our pressure washer...lol
driftking777 is offline
Old 12-19-2008, 12:47 PM   #18
S14DB
AFC #1
S14DB's Avatar
"Fragrance levels will be reduced on vehicles equipped with catalytic converters."
S14DB is offline
Old 12-19-2008, 12:47 PM   #19
Brian
Brian's Avatar
Trader Rating: (54)
I don't want fruity gasoline.
yuck.
Brian is offline
Old 12-19-2008, 12:50 PM   #20
LongGrain
LongGrain's Avatar
wow really? around here this summer race gas was like 5.50
but that was when normal gas was like 4.xx so its probably even cheaper now.
Old 12-19-2008, 01:00 PM   #21
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
+1
I dont think you even need high of a mix ratio to get the smell.
VQMaxFan is offline
Old 12-19-2008, 01:19 PM   #22
projectRDM
projectRDM's Avatar
Ya, the times I've ran 103 I just mix it, 3-4 gallons per tank, bump the timing a degree and go. Doesn't feel any faster but it smells nice.
FORMERLY R240NA
projectRDM is offline
Old 12-19-2008, 01:35 PM   #23
slider2828
slider2828's Avatar
There is permanent damage because at high end you will not have complete burn. Overtime that will cause some damage to the pistons and rings as it will seep through your rings into your oil and that destroys the lubrication properties of oil.....
Turn and Burn!
slider2828 is offline
Old 12-19-2008, 01:49 PM   #24
S14DB
AFC #1
S14DB's Avatar
It's not going to wash down running higher octane. That's only if he had a extremely rich AFR no matter what the octane.
It will just burn slower then a lower octane. As long as the AFR is good he will get a complete burn. It will just be later then normal. You won't get as much power. Why it was suggested he advance his timing.
S14DB is offline
Old 12-19-2008, 02:51 PM   #25
slider2828
slider2828's Avatar
Hmmm that is true....
Turn and Burn!
Old 12-19-2008, 03:16 PM   #26
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
Originally Posted by McRussellPants View Post
Put in Racegas
profit
SOUNDS LIKE A PLAN!!!!!
BRAIN I AM SEND A FUCKING ECU! to you...
gimmie your address NOW!
If you like it send me your ecu and $50!
You gotta see the power from these...
pm me well talk... you need more than that na ka oem ecu can do...
hit me
sillyvia13 is offline
Old 12-19-2008, 03:28 PM   #27
lflkajfj12123
so you're saying
if i put 93 octane in my stock ka i'm actually losing power..
so putting 87 in my tank is actually better
some one hit me with some knowledge
lflkajfj12123 is offline
Old 12-19-2008, 03:29 PM   #28
Def
This thread is full of fail.
Combustion rate is NOT directly related to octane rating of a fuel. There is some race gas that has a faster combustion rate than normal pump gas, and some that has a slower combustion rate of the gas. VP Import stuff in particular touts its higher combustion rate to enable a small increase in power at very high RPM(<8000 RPM).
Def is offline
Old 12-19-2008, 04:32 PM   #29
racepar1
racepar1's Avatar
so you're saying
Ka's are supposed to run on 91 octane, that is what you should run. I get a bit of pinging in hot weather from 87 octane, so I stick with 91. I doubt you will lose anything with 93 octane, but with 110 octane you probably will.
In all cases, no. Generally speaking though higher octane means slower combustion. You can get race gas that will burn as fast or faster then pump gas, but most race fuels don't. What higher octane really means is a higher resistance to combustion. It takes higher cylinder pressures and/or temperatures to burn higher octane fuels efficiently then it does to burn pump gas efficiently.
racepar1 is offline
Old 12-19-2008, 05:41 PM   #30
Def
Absolutely 100% incorrect on all counts. Burn kinetics at the same octane rating, but with a fuel made of up different compounds(more aromatics, more TEL, etc.), will be vastly different.
Tuning cars on different fuels, and learning a few things about combustion engineer makes this readily apparent.
Def is offline
