Old 12-19-2008, 10:58 PM   #1
wrxn240
wrxn240 is on the path to ruinwrxn240 is on the path to ruin
Ka24de Serious Wiring Harness Help
Ok this is my 1st motor swap and alot of wiring/powertrain was missing from the car when I bought it, so I'm having to figure out alot by myself. 89' 240 with a dual cam swap. Got everything in ok, but when I tried installing the harness I ran into some problems.
FYI- i removed the power steering and a/c
plugged everything in i could find, but have some connectors left over on the harness (some prolly go to ps and a/c) and i also have a bunch of connectors left over on the actual motor itself.
These 3 connectors are coming out of the fuse box. what connects to them? tranny harness? harness from alternator to battery?
also coming out of the fuse box on the other side of the box from previous pic
2 wires branch off. one goes to maf and the other??
number 1 goes to the coil. number 2 and 3?
this wire isn't part of the harness. comes from bottom of the coil, and then to where? doesn't match any of the connectors from the harness...
this connector is right by the oil filter. no connector from the harness fits it..
this branch is from the ecu to the body harness by the battery. there's a connector half way that goes somewhere...
Is there a seperate harness that goes from the battery to the alternator with some connecters? cus i don't know what plugs into the alternator. Also, what does the tranny harness connect to...sorry for all the questions it's just difficult having nothing to relate to. hope u understand
wrxn240 is offline   Reply With Quote
Old 12-19-2008, 11:59 PM   #2
wrxn240
ok nevermind i feel stupid for posting this. anyone got a lower harness 4 sale
Old 12-20-2008, 04:52 AM   #3
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
i got one...somewhere O_o
tre4s13 is offline   Reply With Quote
Old 12-20-2008, 05:23 AM   #4
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
i have one lmk
Killa_D is offline   Reply With Quote
Old 12-20-2008, 09:40 AM   #5
projectRDM
projectRDM's Avatar
1) Lower harness plugs to alternator, transmission, starter.
2) Same.
3) P/S high pressure switch.
4) Coil and power transistor. You need to use a DOHC coil.
5) P/S pressure switch again.
6) Oil pressure switch. Plug is on the lower harness.
7) ABS skid sensor for right front wheel.
FORMERLY R240NA
