Old 05-21-2003, 08:48 PM   #1
ghosts14
ghosts14 is an unknown quantity at this point
Front end issues
The front end on my 96, just doesn't feel as planted as it used to be. Basically is feels kind of like the front end of the car kind of sways when just crusing at freeway speeds.
What would cause that kind of problem and how would one fix it?
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
-HotShot Headers; Ran. Tech Cat; 5Zigen Border3
-KYB AGX's; H&R Springs
-Whiteline front and rear swaybars
ghosts14 is offline   Reply With Quote
Old 05-22-2003, 02:10 AM   #2
driftingpanda
driftingpanda's Avatar
Trader Rating: (24)
driftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond repute
Feedback Score: 24 reviews
Send a message via AIM to driftingpanda
there could be couple of causes that i can think of... first, check your alignment, some toe out might cause the freeway floating problem. second, take a look at your tension rods, the bushings are filled with some sort of oil, and these bushings tend to blow out very, very easily. blown tension rod bushings will cause the car to have shifting alignment. uh... other than that, tie rod bushings, bad camber, camber wear in tires, bad rack-n-pinion, and difference in tire inflation could all be possible causes. but the first two is most likely the case. i hope that helps! good luck.
danny
PM me about limited edition Pink GodziRa Sticker packages!
driftingpanda is offline   Reply With Quote
Old 05-22-2003, 12:13 PM   #3
ghosts14
Thanks for the help, I am taking the car into the alignment shop with in the next week, hopefully that will take care of the issue.
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
