Old 12-29-2008, 09:28 PM   #1
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
Press on brake then idl low....
Ok, there is a previous post about my idl problem that when I turn on the head lights and heater the rpm drop to 700 or lower. Been told to check my alternater.
Now I discover that when I stop at the light and step on brake my rpm drop to 600 or lower... HELP...
pink godzila is offline   Reply With Quote
Old 12-29-2008, 09:50 PM   #2
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
check the vacuum hose that goes to the intake manifold from the brake booster, that happened to me and i checked it out adnd it wasn't on tight enough...
now second thing you should do is take of the part that goes from the firewall to the brake booster, blow on it TOWARDS the brake booster it should NOT let you blow into it, but if you do it on the other side it will let air pass... good time to check that 'valve' also...
maybe this helps you, hope it does...
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 12-29-2008, 10:10 PM   #3
reinvent
reinvent is an unknown quantity at this point
How much of a idle drop?
my car does that with heater and lights. cant remember what happens when i depress brake. i think idle goes up.
It is normal for a slight drop in RPM since when you turn on the lights it causes the alternator to take more HP to spin it to keep up with the amperage demand. My car drops about 50 rpm when I turn my lights on and I have no electrical issues.
reinvent is offline   Reply With Quote
Old 12-29-2008, 10:12 PM   #4
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
+1 on brake booster.
HalveBlue is offline   Reply With Quote
Old 12-29-2008, 10:58 PM   #5
WERDdabuilder
WERDdabuilder's Avatar
same problem here. i was told to check my vacc lines to my brake booster.
still haven't done it ha.
When the power of love overcomes the love of power, the world will know peace
Old 12-29-2008, 10:58 PM   #6
cwallace12
cwallace12's Avatar
cwallace12 is an unknown quantity at this point
Brake booster vacuum lines could be it. Also could be electrical though since hes already having problems with his heater and head lights causing low idle.
cwallace12 is offline   Reply With Quote
Old 12-29-2008, 11:00 PM   #7
B_mart24
B_mart24's Avatar
B_mart24 is a well-known jackass
had same problem on my old s13, just replaced the vacum hose and all was dandy!
B_mart24 is offline   Reply With Quote
Old 01-06-2009, 04:47 AM   #8
WERDdabuilder
bring it back sorry.
ok i replaced the vacc line(had a small cut) and everything is good but when my heater is on full blast the idle drops when i brake/coast to a stop. also my dash light/etc kinda go dimmer. alternater/ground issue?
Old 01-06-2009, 01:00 PM   #9
g6civcx
g6civcx's Avatar
Weak battery current. Could be caused by anything, including alternator, ground, battery, wiring, current leak, big amp/subwoofer, etc.
Old 01-06-2009, 10:41 PM   #10
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
REPS for great advice, right on the money
on most cars the two biggest electrical drains (besides big ass dual fans) occur when you hit the breaks and when you have the defrost on.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 01-07-2009, 02:15 AM   #11
reinvent
Dave
how does braking create an electrical load?
Old 01-07-2009, 02:22 AM   #12
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
brake lights turning on. 4 bulbs to be exact.
Getting better grounds usually helps... make your own grounding kit.
@adrianfromthecastle
