Old 05-22-2003, 12:40 PM   #1
icer
icer is an unknown quantity at this point
s13 disconnecting rear brakes
I don't know if this is possible or recommended, but i have a major problem with my rear passenger side brake and I can't get it fixed till tuesday, i need to drive the car and its grinding to the point i don't think i can. Is there any way to disconnect my rear brakes untill i can get them fixed?
thanks
john
icer is offline   Reply With Quote
Old 05-22-2003, 12:56 PM   #2
Dousan_PG
Dousan_PG's Avatar
my GUESS is off the brake master cylinder. remove the hardline and plug that hole.
not sure on that though..
Aaron
Pink GodziRa
Old 05-22-2003, 12:59 PM   #3
kandyflip445
kandyflip445's Avatar
If it's grinding all the time there isn't anything you can do about it. If not then do what dousan said or do it at the caliper. Just a note...you shouldn't drive without brakes....even if it's just one of them...and I'm suprised dousan didn't say anything about that.
My 240 vBgarage
Old 05-22-2003, 03:20 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
if nothing else, try setting your ebrake as high as possible a few times, that might help you out
otherwise, don't worry too much about it. it won't hurt anything or be dangerous
Old 05-22-2003, 10:59 PM   #5
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Can you tell where it is coming from? I accidentally bumped my dust shield behind my rotor one day. I thought I had a caliper stuck or something, but I just had to push the shield back and it fixed my problem. It made a horrible noise whenever I turned or went in reverse.
RedlineRacer is offline   Reply With Quote
